Left channel issue
As I mentioned in my power cable thread, I’m having an issue with my CDP/dac. A Norma Revo-DS1.
It’s not really static, but more so seems to be distortion in the left channel. It’s not terrible, but too bad to listen to. Seems to affect the highs more than the mids or lows. Here’s a pic. Nothing obvious to me, but that’s not surprising. Thoughts?8eptu7cf2oq5.jpeg
  • tratliff
    tratliff Posts: 1,910
    I'll give it a go.
    • Have you changed cables? Im guessing RCA?
    • Did you move left to right and right to left? Did it follow?
    2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
    treitz3 Posts: 20,367
    Does anything happen when the RCA's or XLR's are installed, the CDP is playing and you wiggle the L channel connection?
    I too see nothing obvious.
  • PSOVLSK
    PSOVLSK Posts: 5,452
    It’s definitely the left channel RCA output causing the issue. I’ve gone so far as to take the CDP to my HT and the issue remains. Currently have another CDP and cheap DAC in my 2 channel and everything is working.
    I don’t have any XLR to try out.
    I haven’t wiggled the RCA’s while they are input and a cd is playing…yet. I will now though.
    Only changes I’ve made to the system recently are switching out PC’s. Haven’t touched any other cables.
    If nothing happens when you wiggle the IC, swap the output IC connections (L&R). Does the issue remain on the L channel?
  • PSOVLSK
    Wiggling does nothing. I’ve changed RCA output, speaker cables…everything you can change. Issue remains in the left channel output.
    Hmmm, are you comfortable removing the main board?
  • PSOVLSK
    treitz3 wrote: »
    I was thinking about that when I had the top off today. With it being, for me, an expensive piece of equipment, I’m not sure I’m comfortable doing too much.
    Understood. You are up in the NY/Long Island area, right?
  • PSOVLSK
    Couple of hours from Dallas
    F1nut Posts: 52,406
    Reflow the solder joints for the left channel RCA jack.
    billbillw Posts: 8,373
    edited February 2025
    Do you have any way to check the output through the balanced connection? It that works, definitely focus on the solder connections for the RCA. Reflowing the correct way will require the board to be removed.
    If the balanced has the same issue, then it's more complicated and I'd probably advise taking to a repair shop.
  • PSOVLSK
    Probably headed to a repair shop as I don’t feel comfortable working on it. My soldering skills are, um, not great.
    Wish I had XLR to connect. I thought about doing that as well. Also, if it worked I wouldn’t necessarily have to have the RCA repaired. Not right away at least.
    VR3 Posts: 29,763
    These don't look particularly healthy?
    VR3 wrote: »
    Those look like that from the factory.
    Looks the same in the 6moons review photo:
    https://6moons.com/audioreviews/norma/4.html
  • PSOVLSK
    Thanks Trey
  • PSOVLSK
    billbillw wrote: »
    VR3 wrote: »
    Somehow I missed this when I replied earlier. Thanks for the info as well as the other suggestions you’ve offered. Much appreciated!
  • marvda1
    marvda1 Posts: 4,972
    Did you check fuses?
    Puritan PSM156
  • PSOVLSK
    Didn't check fuses. I thought if a fuse went bad, it just wouldn't work. I'll check them later. Just ordered some cheap XLR to test with. If they work, I'll probably buy a good pair of XLR and hold off getting the RCA fixed until I can deliver the unit to the Dallas area instead of shipping it. Of course, if I find a bad fuse, I guess it's a moot point.
  • tratliff
    Paul if you find the XLRs work ping me. I’ve got some AQ something’s I’ll ship you. Not the highest end but all yours.
  • PSOVLSK
    tratliff wrote: »
    Thanks man.
  • PSOVLSK
    This post is more appropriate for the “You Know You’re Getting Old” thread because I forgot that one of the XLR on my integrated doesn’t work😳. So…so much for that solution. Checked the fuses and they all look good.
