AQ Chocolate HDMI Cables Good for 4k?
Hey all, finally getting around to setting up a theater area in our current house. I still have my AQ Chocolate HDMI cables that are 8-10 yrs old.
Are these good for today's 4k high speed use?
They were game changers in my previous 1080p setup. If not good for 4k, then what are they still good for in todays world?
Thanks!
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
Atmos: Polk OWM3 x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Answers
  • Hermitism
    Hermitism Posts: 4,353
    EndersShadow Posts: 17,765
    I believe they are HDMI 2.0 certified so I’d say yes.
    I plan to keep using my Cinnamon cables when I upgrade to a 4K tv, unless I find a way to upgrade to carbons lol
  • mantis
    mantis Posts: 17,697
    Audioqest made a few new HDMI cables in the Chocolate range over the years. I assume you have the original Chocolate cables? If they don't say 4k or 4k/8k on the head , they maybe 10-18g cables.
    I suggest before you buy any new ones , test them on your system and see if they limit your max resolution. If they do then you need to get new cables, if not your good to go.
    Dan
  • mufsoman
    mufsoman Posts: 640
    Thanks Mantis! I grabbed a couple Monoprice certified ultra high high speed cables to test, but still having some sound issues as described in my other recent post. Don't think it has anything to do with the hdmi cables though. I've left my Chocolates in the living room sound bar setup. They seem to be working fine there. I'll swap sometime later for a test in the big setup though.
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
