Integrated Amp for LSi15
I recently bought a home and the old owner left their entire HT system behind: 2 LSi15s, 2 LSiFX, LSiC and PSW1000, all of this is being powered by a Denon AVR-3805. I plan on selling the LSiFX and LSiC as I will only ever use this setup for music and the room isn't huge. My question is whether or not the current receiver is adequate or if I should looking to getting a more powerful integrated amp. I'm a complete audio newby and want to keep the whole system simple so I am not interested in separate pre & power amps. I'm open to buying used, what would you recommend?
    pitdogg2 Posts: 27,883
    You do not need multiple threads on the same subject.
  • mantis
    mantis Posts: 17,664
    If you run the LSI 15's in small and use the Subwoofer, you're fine especially in a small room.
    Dan
  • skrol
    skrol Posts: 3,493
    The LSi15 is a hard to drive speaker with impedance dipping down around 2ohms at certain frequencies and need current, not just watts. Speaking from experience you could start out with that receiver but I think the LSi15 will benefit from an amplifier that can drive more current. I ran my LSi15's off an old but hefty Denon DRA-835. The bass just didn't have much impact even with the upgraded woofers. They came to life when I switch to a Parasound HCA-800ii and even more so with my HCA-1000A. The bass tightened up and the speakers just sound right (cohesive). I would consider these amps as low end Parasound but very capable. I hope to upgrade to an HCA-1200ii or HCA-1500 but the HCA-1000A is cutting it for now.
    I had similar experience with my LSi7s that I use in my office. I figured I could just use a receiver and a sub since I wasn't pushing them. They sounded like crap. Then I set the up with the HCA-800ii and they are wonderful.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skipshot12
    skipshot12 Posts: 2,141
    I’ll post my same answer as in the other thread…
    “I’d buy a Krell FBI Integrated (used) in a second if had the scratch.
    An integrated that will drive any speaker thrown at it.”
