A couple questions regarding crossover rebuilds
ChrisD06
ChrisD06 Posts: 929
edited July 2024 in DIY, Mods & Tweaks
No B.S. I'll keep this as short as I can.
1: When rebuilding a crossover with metalized polypropylene capacitors such as ClarityCap CSA series or SoniCap Gen I series capacitors, I can omit the bypass capacitor entirely, correct? No need to keep it there, or replace it with a new capacitor, I can just pretend it was never in the original schematic?
2: In the event I encounter a microfarad (capacitance) rating that is too high, such as 600uF, for any poly caps to be reasonably priced, how should I go about this? If aiming for the highest sound quality, would it be smarter to use like 3x 200uF electrolytics with small tolerances to minimize whatever quality degradation it would add to the signal? This is in reference to an 80Hz HPF which is the first component prior to the entire woofer circuit.
My gear:
  • TCL 75QM7K TV
  • Onyko TX-NR656 AVR
  • RT3000p Fronts
  • CS1000p Center
  • RT35 Side Surrounds
  • RT35 Rear Surrounds
Post edited by ChrisD06 on
    F1nut Posts: 52,005
    1. Correct
    2. Correct
  • ChrisD06
    ChrisD06 Posts: 929
    1. Correct
    2. Correct
    Thank you, Jesse!
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    VR3 Posts: 29,550
    Number 2 depends on where it's at in the circuit
  • ChrisD06
    ChrisD06 Posts: 929
    VR3 wrote: »
    The 600uF HPF preceding literally every other component in the woofer circuit for the RT3000p.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    VR3 Posts: 29,550
    edited July 2024
    Woofer as in midwoofer?
    I would aim for film caps
    6 x 100uf
    12 x 50uf
    24 x 25uf
    Etc
    F1nut Posts: 52,005
    I missed the idea of using electrolytics for the 3x 200uF. Use film as Trey stated.
  • ChrisD06
    ChrisD06 Posts: 929
    VR3 wrote: »
    6 x 100uf
    12 x 50uf
    24 x 25uf
    Etc
    Yes the midwoofer. Will be expensive but I'll get over it.
    If the bypass cap is 3uF in the tweeter circuit, do I still omit it, or is that quite a large bypass cap to be negligible?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    VR3 Posts: 29,550
    3uf isn't a bypass
    VR3 Posts: 29,550
  • ChrisD06
    ChrisD06 Posts: 929
    VR3 wrote: »
    Okay then you just saved me from making a pretty huge error. Thank you very much. I'm going to assume that needs to be a film capacitor in that case.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    VR3 Posts: 29,550
    Yes
  • ChrisD06
    ChrisD06 Posts: 929
    You guys are the best. Time to get to saving up. Will post photos once I rebuild this XO in November or so, I think it's going to be a really fun project.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
