missing schematic of another version of psw111 amplifier
Fabio_rm
Fabio_rm Posts: 63
edited July 2024 in Troubleshooting
It seems to me that, from the photos posted also in this forum, there are two versions of the PSW111 plate amplifier. One is practically the same as the PSW110 with some different and more powerful components, another is radically different. I'm looking for the schematic of the second, the pics are these
  • Fabio_rm
    Fabio_rm Posts: 63
    edited July 2024
    As evidence that there are two versions, this is the pic of the second version, whose amplifier has the same schematic as the PSW110 I already have, where lack the LFE connector
    F1nut Posts: 52,301
    The values are printed on just about every component.
  • Fabio_rm
    Fabio_rm Posts: 63
    I didn't understand the point of the comment, they are two different amplifiers with different projects, I have the schematic of one, the other I don't. I'm a technician and I know how to read an electrical schematic, sometimes need to understand the logic of the circuit to make a repair and not disassemble and test components at random.
    F1nut Posts: 52,301
    edited July 2024
    Well, you could start with the 2 caps circled in red. That sub is infamous for blowing caps and those 2 do not look good.
    Other than that, you can send an email to Polk asking for a schematic. Be sure to mention it is a 230 volt version.
  • Fabio_rm
    Fabio_rm Posts: 63
    edited July 2024
    The bridge rectifier and filter caps are OK, i fear the problem is in the little pcb mounted in vertical, the PWM controller, end i fear the schematic do not show the circuit of that as in the PSW110 schematic, but maybe the problem could be somewhere else on the board and schematic can help to understand it.
    Anyway thank for the idea to contact polk directly, I believed they no aswer but i can tray
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,358
    I have sent the only version of the schematic that Polk has already to @Fabio_rm any other versions are lost.
  • Fabio_rm
    Fabio_rm Posts: 63
    thanks for the bad news :D
  • Fabio_rm
    Fabio_rm Posts: 63
    I wrote to them two weeks ago, they don't reply :/
    F1nut Posts: 52,301
    Fabio_rm wrote: »
    It appears they no longer have the schematic. Time for a new sub.
  • Fabio_rm
    Fabio_rm Posts: 63
    I have already two SUB, one sealed BK Electronics (similar REL) and a PSW110 buyed defective and repaired by myself.
    I like how te Polk Sub sound with my Canton Plus S saltellite, so i thinked to try the PSW111, It have an 8" woofer cone e maybe wil be also better mix whit Canton Plus S. furthermore the PSW110 is too bulky and the colour, light cherry, clashes with the furniture.
    In that case I would keep the PSW111 and sell the other two, I don't know where to put them anymore.
    I founded a PSW111 defective for sale in my city at 40 euro, and I would like to try to repair it, but it is not the usual known heartbeat defect, when turning it on the fuse blows. The seller says he took it to be repaired and the technician told him that the problem is the PWM controller board, but I would not be so sure. That's why I'm looking for the wiring diagram.
  • Fabio_rm
    Fabio_rm Posts: 63
    edited September 2024
    Finally somebody aswer to.
    Marantz Italy service write:
    "Good morning.
    I asked for information to our authorized Italian Polk Audio service center and they told me that the schematic for this model is not available and the replacement board for the amplifier is no longer available.
    Regards."
    Then...nothing to do.
    F1nut Posts: 52,301
    You were already told it is not available.
  • Fabio_rm
    Frankly I can't believe that an authorized service center doesn't have the schematic and they threw away the technical documentation, I can't understand the logic behind it. Evidently this is a company directive or limitations dictated by company transfers to different distributors.
    Viking64 Posts: 7,767
    Fabio was TOLD!!!
  • Fabio_rm
    Fabio_rm Posts: 63
    Viking64 wrote: »
    Fabio was TOLD!!!
    It has been said but there is no logical reason removing the technical documentation from availability. Why? Is it a state secret?
    F1nut Posts: 52,301
    Dude, give it up already.
  • Maurobay
    Maurobay Posts: 3
    Hello! If anyone has the schematic/diagram/service manual for the Polkaudio PSW111, could you please email me a copy? Thanks.
  • Fabio_rm
    Fabio_rm Posts: 63
    edited April 2025
    Maurobay wrote: »
    Ver.I or Ver.II? They are different. Ver.II seems have the same schematic of PSW110, and I just send it to you.
  • pkeenan
    I just replaced C38 and C39. My faith in humanity has been restored. I attached a photo showing where the pins are to the PCB. I'm a true end-user so if I can do it, you can too. Thanks to everyone on this thread!
