Rtia 3
I have a onkyo tx 8050 avr hooked up to rtia 5 in speaker B output.No output goin out on Speaker A.i have a emotiva amp xpa 2 gen 3 hooked up to my pre-outs on receiver to amp and amp hooked up to rtia 9s.Would I
Benefit from hooking up a set of new rtia 3 to the output A on my reciever.
Thx
Best Answer
    VR3 Posts: 29,752
    edited July 2024 Answer ✓
    Outside of all of this...
    Hooking up another set of speaker playing the same signals will result in some crazy response curves. You will boost some frequencies and cancel others.
    Ultimately the rtia9 are capable of far greater volume then the rtia3 can ever dream of, especially in a room that large.
    What you need is a much larger set of speakers for a room that size. The rtia9 is a baby in that space, imo. Especially if you are getting after it.
    Tyler acoustics offered a series called the pro dynamic and can be found relatively cheaply on the used market. They use pro drivers and are the size of a refrigerator. That would be my recommendation!
Answers
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,386
    Hello,
    Welcome to the Polk forum. It looks like the Onkyo is a two channel receiver that can be used as part of a network. What function would you want the RTi A3 to perform?
  • jthornhill
    jthornhill Posts: 14
    Just to add the extra speakers up frong along wirh my 9s as ii have a large room.thx
  • rooftop59
    rooftop59 Posts: 8,120
    jthornhill wrote: »
    Thx
    So wait, are you already running two sets of speakers in the same room and you want a third?
    Game Room 5.1.4:
    Bedroom 2.1
  • jthornhill
    Yea thats correct
    txcoastal1 Posts: 13,520
  • jthornhill
    Lol.I have volume control on all 4 speakers that hook up to my receiver seperate.thx
    F1nut Posts: 52,406
    edited July 2024
    Get some PA speakers and bridge a couple of Crown pro amps.
  • jthornhill
    I was goona do that but I was given the rtia 3 so i figured I just add on to my empty spot on receiver and then will at least have all same series of speakers was my thinking and if to loud or what have ya I would just adjust volume on the 3.thx
  • rooftop59
    To me, that would sound ear-piercingly terrible. But it shouldn't be a problem as long as you don't crank it to high. Try it, if you like it, rock on.
    Game Room 5.1.4:
    Bedroom 2.1
  • Unknown
    Clipdat Posts: 13,104
    Maybe this is the cousin of the guy with 6 LSi15 towers surrounding his bed.
  • SeleniumFalcon
    In general terms, unless the system is a multi-channel type with each speaker reproducing a different sound (left channel, center channel, right channel, surround channels) a two channel system satisfies best with two speakers each contributing to a solid imaginary stage in front of the listener. In fact people put lots of effort and money in eliminating unwanted extra sound sources that tend to confuse building this imaginary image.
    But, there's the old adage, "Try it and see if you like it!"
    F1nut Posts: 52,406
    jthornhill wrote: »
    I suggest you try to learn what good stereo is supposed to sound like. Maybe visit an audio store or attend an audio show.
  • jthornhill
    Hey keep comments like that to your childish self.No need for comments like that if ur any man at all.I had more top notch stereo gear than you ever had or will have.I seen ur ignorant post before to people trying to get answers and you come back with some sarcastic remarks.What gear u have you knowledgeable smart **** kid.People want sensible remarks not stupid,ignorant and childish remarks.
    You came here for an opinion
    Viking64 Posts: 7,814
  • Unknown
    edited July 2024
  • jthornhill
    The question was is or was a good idea.Just wanted opinions not smart **** ones
  • jthornhill
    The room is 28’ by 32’ with 20 ‘ ceiling
    "I seen ur ignorant post"
    F1nut Posts: 52,406
    edited July 2024
    jthornhill wrote: »
    LMAO
    It's a shame you don't recognize constructive advice, but then again after reading your posts I'm not surprised.
    Good luck, you'll need it.
  • Unknown
