60 Hz hum
AndyBrunk
AndyBrunk Posts: 1
edited February 2005 in Troubleshooting
I've recenly noticed an annoying hum (probably 60 Hz) from my RMDS-1 at all times except if the power is turned off at the sub.
I have made sure that all componets connected to the system share the the same power and phase.
Any ideas?
Post edited by AndyBrunk on
    F1nut Posts: 50,841
    edited June 2004
    Sounds like a ground loop problem with the sub amp.
  • ntilden
    ntilden Posts: 5
    I had the same problem. I solved it by simply plugging the power cord into a 2-prong cheater-plug (without the 3rd grounding prong).
