Woodbourne Speaker Doesn't Turn On: Possible Causes?
I have an old Woodbourne speaker that suddenly stopped working. It was unplugged for about a month and when I plugged it back in, it won't turn on. No lights, no sign of life, I tried both with the front buttons and the remote. What could be the possible causes and is there a potential relatively easy fix, like replacing a fuse? If so, how do I do that?
I really like the design and the sound is very pleasant, so I would hate to throw it away. Polk hasn't designed anything new in this category that is a worthy successor, either. So, any help is greatly appreciated.
Answers
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,353
    I'll check with a friend at Polk to see if there is some troubleshooting you can try.
  • SeleniumFalcon
    Unfortunately there isn't much troubleshooting possible with that unit, I'm afraid. The front grille cloth isn't easily removable and Polk doesn't have any repair capability. I wish I had more positive information for you.
    F1nut Posts: 52,244
    Woodwoman wrote: »
    I suspect the feet on the bottom pop out to expose screws, which would allow one to access the workings. Perhaps there is a fuse in there, perhaps there is a loose connection, perhaps a bad capacitor...lots of perhaps. My understanding is the failure rate of the Woodbourne was very high and you're lucky yours lasted this long.
