Help sourcing Polk Lsim 706C 6.5" driver
zvucnik
zvucnik Posts: 55
edited February 2024 in Troubleshooting
Dropped the speaker and both drivers aluminum brackets cracked. I was able to find one locally but need one more. Part number is RD 6675-1 and Polk customer service told me they are out of production and will not be getting any.
So if anyone has one sitting around or know where I can get one it would be much appreciated!
any other Polk drivers that would work in this application?
  • stangman67
    stangman67 Posts: 2,330
    I think I have one. Let me check when I get home
  • Emlyn
    Emlyn Posts: 4,895
    I've heard that the cast baskets on those are weak, but that's clear evidence of them being REALLY weak!
    I've occasionally seen someone parting out LSiM speakers on Ebay but don't see any 6.5 inch drivers right now. Hopefully stangman67 or someone else has one available.
    VR3 Posts: 29,715
    What's sad is that it's a very nicely designed woofer.
  • zvucnik
    stangman67 wrote: »
    that would be great!
  • zvucnik
    @VR3 I wonder if I could epoxy/jb weld these brackets?
  • ken brydson
    ken brydson Posts: 9,093
    zvucnik wrote: »
    That was my thought. Wouldn't hurt to try...
    F1nut Posts: 52,346
    Stamped steel baskets would never do that...just saying.
    3M makes industrial structural epoxy products that will bond far better than regular epoxy and especially better than JB Weld. I recommend DP 420. You'll need to clamp it and also apply some extra around the broken area on the spokes.
    F1nut Posts: 52,346
    Hang on, I didn't notice in the first 2 pics that the spokes are broken at the top. Those are toast!
    Toolfan66 Posts: 18,399
    OUCH!!!! :'(
  • gyosa
    gyosa Posts: 770
    Isn’t there supposed to be some sonic benefit to cast baskets vs stamped steel ?
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • Hermitism
    Hermitism Posts: 4,347
    gyosa wrote: »
    Bk
    They don't ring like stamped steel when you flick them with a fingertip. That's why a lot of us apply Dynamat to stamped steel baskets, dampening the vibration.
  • zvucnik
    just to follow up, I was able to find both drivers locally. will still try to cold weld the baskets. will update with results :-)
