Where to get a replacement driver woofer 6.5, for t50 polk?
Hello,
I'm new here. I have 2, T50 tower speakers, and the 6.5 woofer quit working. The only numbers on the woofer are T50 WF, and 18 01 17. I googled that and came up with nothing. No other numbers or anything on them.
They are powered by an onkyo TX-SR373 receiver. This is the 2nd time it quit. The first time best buy gave me a new tower. Any reason why it blew? I do not blast this really loud.
Will any 6.5 woofer work in those towers? Anyone know any replacement part number or anything?
Thanks for your help
  • SeleniumFalcon
    Hello,
    Welcome! I would recommend calling Polk's CS at 1-800-377-7655 and follow the prompts to the parts department.
  • Wesly
    Wesly Posts: 1
    mám ten samej problem.jak jsi pochodil donte?
    F1nut Posts: 52,261
    Wesly wrote: »
    Translated..."I have the exact same problem. How did you make out?"
