My Current Setup - Y'all Think
In My Setup / Collection:
SDA SRS 1.2TL
SDA SRS 2.3TL
(1) Hafler DH-500 amp
(3) Hafler XL-600 amps
Hafler Iris System w/ Remote
(2) Hafler DH-110's
Symmetry ACS-1 Crossover
(2) Sony Cd Players
    pitdogg2 Posts: 27,488
    UMM, your SRS 2.3tl's are backwards.......Sooo I must wonder if the 1.2tl's are as well.....
  • Astrl55
    Astrl55 Posts: 68
    I feel like the star of that setup is the Panasonic 8-track player/recorder.
    Clipdat Posts: 13,100
    Needs more **** stacked on top of the speakers.
    Viking64 Posts: 7,675
    Ivan, do you know if the original (non-TL) 2.3s were opposite (4 drivers outside, two drivers inside) than the 2.3TLs? I had a guy tell me mine were in the wrong position. He had worked in an audio store back in the 80s and was certain mine were wrong. :p
    That rack needs a few more Haflers below carpet level.
  • I just moved them into a new room for now, haven't got them positioned correctly or hooked up at the moment.
  • gyosa
    gyosa Posts: 770
    Noticed the Harrier …
    You fly them ?
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • My father in law did, he passed last year
    msg Posts: 10,512
    Is there something wrong with Hafler amps?
    mhardy6647 Posts: 35,342
    msg wrote: »
    In general, nope, nothing at all.
    David Hafler begat (in this order): Acrosound, Dynaco, and Hafler.
    nooshinjohn Posts: 26,043
    neuschww wrote: »
    Semper Fi and Godspeed to the father-in-law...
    Welcome to the club.
  • aprazer402
    aprazer402 Posts: 3,434
    edited January 2024
    I agree your 2.3TL's are reversed. You asked for opinions, I guess; "Y'all think" so...
    I've had countless CD players, many were Pioneer, a few Pioneer Elite ones and
    by far the worst sounding one is the one you have in the rack, a PD-M423. The
    poor sound of these is very obvious when compared with about any other CD
    player of similar vintage. Just swap it out with pretty much anything and it will be an
    improvement.
    All else looks good, I have 2.3 non-TL's and 1.2TL's. Enjoy the music!
    EDIT: Your available space may be limited, but the 2.3TL speakers should be farther apart and should not be back the 3-4 inches from the front of the rack. They should be on the same plane or just protrude a half inch in front of the rack. There are SDA side wall distance recommendations also, but we can't see the right wall location in the photo.
    Welcome to the forum! I just saw your post above that you had just moved them into a new room and they are not set up correctly, my apology.
    Toolfan66 Posts: 18,258
    I would ditch the 1.2tl’s and focus on setting up the 2.3tl’s properly, your ears will thank you..
    Viking64 wrote: »
    Yes the original 2.3 had the donut drivers top and bottom of the outside 4 driver array. In other words opposite of the 2.3tl.
  • Toolfan66 wrote: »
    The 2.3TL's are better than the 1.2TL's? Why is that, What has been done differently besides the obvious numbers of drivers and tweeters?
  • aprazer402 wrote: »
    improvement.
    Thanks for your info on the CD Player, I didn't know they were that bad.... Guess I'm off Shopping for a new one.
  • aprazer402
    neuschww wrote: »
    aprazer402 wrote: »
    improvement.
    Two pieces down in your rack is a Sony disc player, use that for CD's instead, it should sound better.
  • Gardenstater
    Gardenstater Posts: 4,841
    When flexing goes wrong.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    audioluvr Posts: 6,004
    You should get rid of the haflers. They're terribly bright and fatigueing. The 2.3tl's sound okay (Better than the 1.2tls) but I'd get rid of them too for the the SDA2B's or better yet the 7b's!
    F1nut Posts: 52,104
    neuschww wrote: »
    Toolfan66 wrote: »
    The 1.2TL projects the sound above your head like you're sitting in the orchestra pit. The 2.3TL projects more like you're in the 10th row level with the musicans.
    edited January 2024
    neuschww wrote: »
    Toolfan66 wrote: »
    This, and my post below,
    neuschww wrote: »
    Toolfan66 wrote: »
    I’m not saying they’re better, I’m looking at how you have everything crammed together in what looks to be a fairly smaller room, the 2.3tl’s will do everything and then some for you.
    You’re not doing the speakers or your ears any favors having them pushed together like that.
  • When flexing goes wrong.
    I am Not flexing, I just wanted to post what equipment I have, At the moment none of it is hooked up, I had to move it into a smaller room for now because I am remodeling the larger room that they will go in.
    msg Posts: 10,512
    Yeah, get off 'im @Gardenstater
    edited January 2024
    So you ask what we think of your setup, and when a few point a couple things out, nothing is hooked up, and just stored in this room?
    Yes, Its not hooked up at the moment, when it is, they are setup correctly with the correct X,Y and Z Spacing. Of course not all preamps are hooked up at the same time, but I have those because I found them that someone was trying to basically throw them away and I wanted to save them. I'm not complaining at all that I'm getting feedback, whether it's positive or negative, That is why I posted it. I thank everyone for their input!
  • DarqueKnight
    DarqueKnight Posts: 6,765
    On must recordings, in my room, my 1.2TLs do project the sound over my head when I am sitting down, as if I am sitting in front of musicians standing in front of me. If I stand up, I am face to face with the musicians. On some orchestral recordings, some instrumental images do come from above the speakers.
  • JCL
    JCL Posts: 172
    I have original 2.3’s with the donut drivers and mine would be set up like you have. That being said yours should be reversed if they are the tl’s. I’m supposed it doesn’t say on the back of the speaker which is the left and which is the right.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • JCL wrote: »
    Normally they are setup correctly and they do show left and right on the dataplate on the backside. Thanks
