Sound bar
Sound bar not syncing.Green light is not flashing on at all. What do I do?
  • Jimbo18
    Jimbo18 Posts: 2,351
    There are a lot of knowledgeable people on here that might be able to help you but they will need more info. What brand of soundbar? Model number? How is it hooked up? What setting in the soundbar and the TV? Ya know, stuff like that.
  • msg76
    msg76 Posts: 7
    It cannot sync if there is no signal being received.. I would start there; "Divide and conquer" BTW: are using the soundbar remote or your television / satellite remote ?? I have found that the soundbar has a very narrow line of sight for its remote signal.
    audioluvr Posts: 6,079
    I really want to know what's correct. Sound bar? or Soundbar?
  • ken brydson
    ken brydson Posts: 9,108
    audioluvr wrote: »
    Well then is it Snickers Bar or Snickersbar?
