Completely new to speakers. No sound coming from tweeters of lsi15's
blueskies
blueskies Posts: 33
edited January 2024 in Troubleshooting
I already have two lsi15's that sound absolutely great. But I bought another pair to add to my set up and I the tweeters aren't working on both speakers. If I hook up the speaker wires to the connectors at the bottom, the rest of the speaker sounds great as well as the subwoofer, but the tweeters aren't working, but If I connect the speaker wire to the top connectors, only the tweeter works with barely any sound coming out at all. The rest of the speaker doesn't work. I took a tweeter out of the pair that are working fine and it made no difference.
I disconnected all of the speakers from the receiver and tried them out one at a time.
Does anyone know what the problem may be?
  • boston1450
    boston1450 Posts: 7,759
    edited January 2024
    Not sure on that model can you try using jumpers OR speaker wire. Top to bottom on bindings - where your speaker wire / cable goes.. EDIT If you already use same speakers - are they the same where wire/cables hook in ? Maybe the metal tab / jumper is missing
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    F1nut Posts: 52,406
    To expand, your original speakers have gold colored plate jumpers between the top and bottom binding posts. It appears those are missing from the pair you just purchased. You will need to make a pair of new jumpers by using short pieces of speaker cable.
  • blueskies
    With the original speakers, I just connect the speaker wire to either the top or bottom connectors and they sound fine.
    So after I make a pair of jumpers, it will solve the problem?
    F1nut Posts: 52,406
    Do you have these on your new speakers? If not, you need to make some from speaker cable.
  • blueskies
    Thanks for this. I just looked and I don't have them. Would you happen to have a link on where I can buy these?
  • boston1450
    Just be very very careful. One guy tried it & he never reported back :D
    Randy-Maine
    by David WMG
    F1nut Posts: 52,406
    blueskies wrote: »
    Well, they tend to vary in size/length depending on the binding post plate used, so finding the exact size you need would be a crap shoot. In reality, you are much better off using speaker cable as those gold plated brass plates leave a lot to be desired.
  • blueskies
    Thanks. I took the jumper plates off the originals and now they sound great. I will give those in the link you provided a try.
    Thanks again!
  • boston1450
    Welcome to the forum & Kudos for quick responses.
    Randy-Maine
    by David WMG
    F1nut Posts: 52,406
    blueskies wrote: »
    Thanks again!
    Ok, but sonically using speaker cable is better.
  • gp4jesus
    gp4jesus Posts: 2,025
    … using speaker cable is sonically better.
    The above and for the fitment reasons he mentioned in earlier replies.
    *all connected w/Premiere ICs
  • geforce
    geforce Posts: 1
    Hello! I'm new to wired speakers and started myself with a pair of used TSi300s. I seem to have ran into the same issue here. I have the jumper plates on both bindings. I'm using speaker wire with banana plugs. When I connect the top bindings, only tweeters work, when I connect lower bindings, tweeters don't seem to work. What could be the cause? I'm very puzzled. Thank you so much in advance!
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,405
    Hello and welcome! From your description it would seem that the binding post jumper plates are not installed correctly. Loosen up all of the binding post caps and make sure the metal area of the jumper plate is touching the metal of the binding post shaft. The incoming signal has to reach both the upper and lower binding posts via the jumpers.
    F1nut Posts: 52,406
    geforce wrote: »
    Please post a few pictures of where you have the speaker cables connected to the binding posts
