Thoughts on PS Audio Jewel powercable?
Looking to see if anyone has thoughts on this?
Found one for a good deal and it’s the only PS Audio cable I’m aware of with a C7 connector.
Thoughts appreciated
    F1nut Posts: 52,301
    Beats a stock power cord. I had and may still have one on some piece of kit.
    EndersShadow Posts: 17,749
    Good to know. Its overkill for an Xbox Series X I’m sure but my old Xbox One had a AC-3 so I’m familiar with overkill (and the Series X uses an internal PSU with a C7 so I can’t reuse the AC-3)
  • Emlyn
    Emlyn Posts: 4,888
    PS Audio also made the Punch cord with a C7 connector. I still have one of those in my bag of tricks but nothing to use it with anymore. It was well constructed and relatively inexpensive. 12 AWG and double shielded. I got one for use with a DVD player probably 20 years ago.
    https://forum.polkaudio.com/discussion/37703/ps-audio-xstream-power-punch-the-silk-panties-of-power-cords
    F1nut Posts: 52,301
    Sorry Dan, mine is/was the Power Punch.
    edited December 2023
    Emlyn wrote: »
    No prob. Looks like both the Power Punch and Jewel were both their entry level cords but the Power Punch may be the precursor of the Jewel.
    I think for the price I can’t go wrong on it so I’m gonna snatch it up.
    I had a prelude which seems to be in the same age as the Power Punch and it was a bit too stiff (prob a thicker gauge but I forget) whereas the AC are more flexible (and the jewel shares the same connectors and seems flexibility).
