SDA Interconnect Question
OK, so I've gotten around to rebuilding a pair of SDA 2B's I picked up a while back. These have pin/blade connectors and didn't come with the OEM cable. I had planned on replacing the stock IC connectors with Neutrik plugs. But now that I'm taking a closer look, it appears that just one wire actually carries signal between the speakers. Since my amp is common ground, now I'm thinking I'll add a third banana plug for the interconnect and leave the old pin/blade socket in place. Is this a bad idea? Stick with the Neutrik?
    pitdogg2 Posts: 27,490
    Sitka wrote: »
    Stick with the Neutrik. Wire the Neutrik just like it is wired now. Common ground amp or not throwing a 800va transformer in the mix does have beneficial results and if you find a good dual mono or any number of non-commom ground amps you're ready to go. You're in there do it up right the first time.
  • Sitka
    Sitka Posts: 77
    Thanks Pitdogg, I'm new to the SDA world - but for now I'll proceed with the Neutrik install. I assume you're referring to a Dreadnought transformer?
    edited December 2023
    Sitka wrote: »
    Yes I was referring to the stock, off the shelf 800va transformer.
  • Sitka
    Sitka Posts: 77
    Wow, now you've got me going down the Dreadnought rabbit hole! Maybe after I finish reworking these 2B's. Question - is there any particular brand of 800va transformer you like, and must they be 115-115v secondary voltage?
    Here's some pics of the Neutrik install and the finished CO board.
    F1nut Posts: 52,109
    Avel is the brand, someone else will post the Model number.
  • Sitka
    Sitka Posts: 77
    Thanks F1 I think it's the Avel Lindberg Y236906 which I'm trying to find for sale, but no luck yet. Parts Express has a dozen others from Avel but no Y236906. I'll contact them directly after the Holidays.
    audioluvr Posts: 6,004
    They are direct only from Avel. Call them and talk to Heather? She can take your order
  • Sitka
    Sitka Posts: 77
    Thanks Audioluvr - will call them next week.
    xschop Posts: 5,567
    edited January 2024
    Sitka wrote: »
    Waiting on Avel email myself. Parts Express has every one but the 906 lol.
    @Sitka, Are you installing Neutriks on your dreadnaught or binding posts?
  • Sitka
    Sitka Posts: 77
    edited February 2024
    Sorry @xschop, it's been a little busy around here. Here's what I have so far:
    Trying to keep costs down while maintaining quality. Everything except the torroid came from Partsxpress. Will add the Dynamat later.
    xschop Posts: 5,567
    Good job. I got the same 800VA and I see your wires exit upwards the torroid also.
  • Sitka
    Sitka Posts: 77
    My Yamaha AS 2200 is a common ground amp hooked up to a pair of SDA 2B's with TL mod. However, with the Dreadnought now attached - big improvement in soundstage and imaging. It may have also improved tweeter clarity as well. Also without the Dreadnought, the amp ran slightly warm - now running cool. I built a short 3' interconnect and left the SDA cable in tact, so tomorrow I'll play around with some A B comparisons with and without the Dreadnought. First impression is it's worth the effort and cost. Thanks to all for your generous help!
