rti150 grilles
gradyj
Hi, I've got a pair of Rti150's which I really like. Problem is the grilles won't stay seated.. they keep popping out, usually around the bottom. Any solutions besides removing them all together?
John
John
Post edited by gradyj on
Hello John,
There is a trick you can do to keep them in place. The small plastic pins, on the grille cover, are called "treelocks". If you remove the grille cover and take a pocket knife to "rough up" the plastic end of the lower treelocks to create a little more friction with the treelock when it's placed into the opening. Just a bit of gentle scraping with a blade will add enough roughness to cause it to fit tightly.
Regards, Ken -
thanks.. I'll give it a try
