PSW1200 Volume Control
Hello all,
I have a PSW1200 that i've owned for over 20 years. I've noticed lately that when i attempt to adjust the volume via the dial on the front, it produces a scratching sound out the speakers and does not adjust the volume in proportion to the setting. Sometimes when i stop adjusting it, there is no sub volume. Sometimes the volume is extemely high, even though the dial only shows a 4 or 5. It's gradually gotten worse over the last year or so, and is now a major problem.
I've not made an attempt to remove the volume knob or test it in any way. Just wondering if anyone else has had the same situation, and whether they were able to resolve it.
Polk support was less than helpful. No replacement available, exact or otherwise, and they said they do not have technical specs for the volume control dial (what?). They recommended i look on the Polk forum, lol....
I love the speaker, and want to fix it. Any help would be welcome and appreciated!!
Thank you in advance!
Best Answer
  • ChrisD06
    ChrisD06 Posts: 929
    Answer ✓
    The cover of the volume knob (the plastic face with the logo and LED) is capable of coming off. Facing it, just pull it straight out towards you, not too hard or the LED cable will get yanked and can break. Inside is your potentiometer. Same design as my RT3000p.
    I believe the inside of the volume dial cover has the model on it?
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
Answers
    F1nut Posts: 52,258
    It appears the volume knob is under the Polk Audio logo on the front of the unit...strange. Anyway, you would need to remove the volume control knob to find the specs, which should be printed on the back. It may even have the name of the manufacturer that supplied the control. Once you have that info it should be easy to search for the proper replacement.
  • Elsie659
    Chris,
    Thank you so much!!! It came right out just the way you said it would. Appears to be an Alpha A250K. Looks like the connections are potted, so just need to remove that without damaging anything and should be able to get it fixed up in no time.
    THANK YOU!!
    Shawn
  • ChrisD06
    ChrisD06 Posts: 929
    Elsie659 wrote: »
    Chris,
    THANK YOU!!
    Shawn
    Awesome! Glad to be of help.
    Just a suggestion, and I've not tried this but I was recommended it by a local vintage audio guy, but: maybe try DeoxIT F5? It claims to be gentle on plastic and it's designed to clean pots. Perhaps all the pot needs is a cleaning.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    pitdogg2 Posts: 27,720
    edited December 2023
    https://www.amazon.com/Hosa-F100L-L25C-DeoxIT-FaderLube-Dropper/dp/B0018P6DPW
    https://www.amazon.com/CAIG-LABORATORIES-D100L-25C-Contact-Cleaner/dp/B0000YH6F8
    These two are all you'll ever need.
    The deoxit chris pointed to is only a 5% solution. It's 95% other stuff that evaporates away. The needle bottles are much superior in getting it where you need it.
    Now in the past most of these type of pots have carbon wipers and they do tend to build up crud. You can also try running it back and forth full range a bunch of times to try and clear it to make better contact. Canned air is also an option.
    Use the deoxit then the next day use the fader lube and if those do not help you're out of options and need to replace.
    Both run fully back and forth a good amount is helpful.
    F1nut Posts: 52,258
    $3.48
    https://www.stewmac.com/electronics/components-and-parts/potentiometers/alpha-control-pots/
    Dab denatured alcohol onto the hot glue, wait a few minutes and it will peel right off.
    You're welcome.
