Pin broken inside subwoofer connection
How can I replace that LFE in connection?
    F1nut Posts: 52,292
    That RCA jack is ruined. So, remove the plate amp. Then desolder the RCA jack from the board. Unscrew the jack from the plate and install a new RCA jack that matches the original.
    If that is beyond what you want to do or are capable of take the sub to an audio repair business.
  • ClintonH
    Thank you! I’ve been looking on Amazon, but was unsure how to get that part.
    pitdogg2 Posts: 27,764
    edited October 2023
    First you'll need to take the amo out to see how it's configured on the board. If you wanted you could take a picture and post the picture and maybe we could help you find the best option.
    F1nut Posts: 52,292
    ClintonH wrote: »
    If you do a Google image search for "through hole rca jack" you will see there are many types, so as stated you'll need to remove the plate amp in order to find out which one you have.
