A small room, only 416.5 square inches
Friends, in a small room, only 416.5 square inches, should I really settle for the STEREO structure (2.1, 2 front speakers and 1 subwoofer)? Or can I try an ATMOS 5.1 or even 7.1 setup?
Answers
    Viking64 Posts: 7,739
    416.5 square inches is less that 3 square feet. If you give the room dimensions in feet x feet, someone might be able to answer your question more accurately.
  • remomoreira
    113,5 square feet.
  • daddyjt
    daddyjt Posts: 3,207
    ― Aleksandr Solzhenitsyn
    Please select all of the images with a castle in them to prove you are a human.
    VR3 Posts: 29,659
    Building the coveted half bath rig... A sure sign you have made it
    audioluvr Posts: 6,037
    Jesse's coffin is probably 416 square inches if you stood it up on end. I wonder what sound system he's using. :D
  • Emlyn
    Emlyn Posts: 4,888
    10ft by 11ft is a fairly common size for a spare bedroom in the US. I have a pair of Wharfedale Lintons and a Polk LSiM704C center speaker at a house with a room/den that size. It's mainly used for watching movies and TV. No need for a subwoofer and no need for an Atmos setup for my purposes but in-ceiling and in-wall speakers could be used. It would be overkill in a room that size but it could be made to work.
  • stangman67
    stangman67 Posts: 2,330
    Yea I had a 10x11 room in my last house, I wouldn’t do a full 7.1 system in them but you could do 5.1. I had multiple 2 channel systems in that room, the biggest being Focal Aria 926’s on 200 watts each and it sounded great!
  • ken brydson
    audioluvr wrote: »
    Soundbar silly..
    F1nut Posts: 52,244
    audioluvr wrote: »
    Soundbar silly..
    Never!!!
  • sm1th5
    sm1th5 Posts: 18
    5.1.2 atmos even in the smallest of rooms.
  • rooftop59
    rooftop59 Posts: 8,120
    I mean you’re free to try anything man! Don’t know if it would be worth it…is the space primarily for movies and tv or 2 channel music? I think you might be surprised how good 2 or 2.1 can sound (even for movies) if the equipment is quality.
    I definitely would NOT go for atmos. You really don’t have atmos until you go 5.1.4, and that seems ridiculous in that room. But some high end cars have surround sound with SACD/DVD-A capabilities, and cabin gain is a great thing: a relatively small subwoofer could still pressurize that room…
    Game Room 5.1.4:
    Bedroom 2.1
