Had my first Car Show vending today
mantis
mantis Posts: 17,637
This was a lot of fun. Most of you know I'm heavy into cars and into detailing so this was a natural move for me . We had a blast, got to talk to a lot of people about their car life and car care.
Dan
  • engtaz
    engtaz Posts: 7,675
    good luck
    engtaz
  • GlennDog
    GlennDog Posts: 3,158
    Is Hyperclean the best easiest product you’ve ever used?
    I’d be down with a one product does all, but prolly not in the cards . . .
    Good luck in your new venture
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • mantis
    GlennDog wrote: »
    I've been around the block so many times with so many different brands. Some are pretty damn good, some other not so much. I have over the years hand selected certain products from brands to create my own preferred line of Detailing products.
    Then I tried Hyperclean months ago. I heard about them , heard all the hype and thought to myself "whatever, I'm sure they are no better then anything I have already used and hand selected". But I was wrong. Shockingly everything they make is a top notch product.
    So case and point, the most unsexy product they make is Glass cleaner. Ok most of us give a crap about glass cleaners until you use everything on the market and basically it all kinda sucks. I found 1 that I actually liked and could get through a set of windows with some work but was able to get a good result. Then I tried Hyperclean's Glass cleaner and I couldn't believe how good it worked, how the towel glided over the glass and I didn't need to use 2 or 3 towels to get the job done. I was able to use 1 which is crazy.
    I purchased a full line of their stuff and just kept being amazed on how each one worked. Then I dug deeper and found out they where developed around high end car collections. These products have to work at the highest level. This is why they do and there is no cutting corners barely any scents in any of them, they finish off fresh and clean. Revive is the interior cleaner and it's hands down the very best of it's kind product I ever used.
    If you ever decide you want to check any out, PM me and I'll send you my number and we can talk about what you need, what your using now and what pain points your products cause you now. I can also save you 10%
    Dan
  • chrispyfur
    chrispyfur Posts: 170
    Cleaning glass is the absolute worst. Out of high school I had a third gen Camaro that I kept meticulously clean, that back hatch glass though..... hated that part of the job the most!
    treitz3 Posts: 20,290
    Aquarium glass cleaner magnets would have definitely helped you with that, FWIW.....albeit too late for you.
  • mantis
    chrispyfur wrote: »
    I had a Firebird of the same generation with that Hatch. I know exactly what your talking about. I use to lay in the back to try and clean that window, it was basically impossible to get clean without streaking all over the place. Glass cleaner back then was terrible
    Dan
  • chrispyfur
    I found keeping the hatch open and sitting in the trunk area was the only way to do it... of course back then I could actually get into that hatch area and twist and turn well enough to make it work!
  • engtaz
    engtaz Posts: 7,675
    Thank you Glass cleaner works very well. Mantis
    engtaz
  • mantis
    engtaz wrote: »
    That level of quality is throughout the entire line. I'm so pleased with this product line.
    Dan
  • polrbehr
    polrbehr Posts: 2,866
    mantis wrote: »
    chrispyfur wrote: »
    Helpful tip from the Peanut gallery - don't clean glass in direct sunlight, especially when it's warm out. That goes for cars, houses, store fronts, whatever.
