Old Windows XP laptop
Does anyone have an older working laptop with Windows XP they want to part with? I'm wanting to do automotive computer programming (performance tune upgrades) and the hardware I run is not supported by Windows 10 which is what I'm currently running.
Thanks.
  • ChrisD06
    ChrisD06 Posts: 929
    audioluvr wrote: »
    Thanks.
    Of course, I'm sure you have specific reasons for wanting a physical piece of hardware...
    However, have you considered running a Windows XP virtual machine on your Windows 10 machine?
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
    msg Posts: 10,534
    ^ good ideer 💡
    I do this for a motorcycle tuning application with VMware Fusion on an old MBP.
    How are you going to get him an XP .iso and key?
    mhardy6647 Posts: 35,373
    edited August 2023
    some of us probably have WinXP distro disks (physical media) someplace. ;)
    I can definitely come up with WinNT disks. B)
  • ChrisD06
    ChrisD06 Posts: 929
    I might have a key somewhere. The ISO downloads are on Microsofts website I believe... you can reuse the same key as many times as you want.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    audioluvr Posts: 6,010
    Got it taken care of. Thanks everyone!
  • skrol
    skrol Posts: 3,480
    I ran into pretty much the exact same issue. I have Volvo's software (VADIS) and DICE interface box that would only run on Win 7 pro. I was able to set up a laptop running Win 10 Home with VM Ware virtual machine running Win 7 Pro and it works perfectly. It even connects to the DICE interface box so I can run diagnostics and record real-time data through the OBD2 port.
    Stan
    Main 2ch:
    HT:
    Other stuff:
