RTi4 crossovers
124»
Answers
  • My AV receiver sounds pretty clean, and even if it weren't, I seldom exceed 35% volume. The only thing I can think of is when I change the HDMI source (IPTV, Firestick or BlueRay) and I get the odd pop sound when it connects, but even then it happens rarely and at low volume. I can't recall any power surge events such as nearby lightning either. I suppose anything is possible.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    Pioneer VSX-521-K AVR
    And a friendly Labrador Retriever
    pitdogg2 Posts: 27,307
    edited September 2023
    Watching movies can have a "ballistic" sounds. Helicopters, gun shots and explosion scenes have been historically my Achilles heel.
    Many receivers now are rated at 2 channels and many time at 1khz not full 20hz-20khz like in the past. 1khz is a very easy way to rate higher power than the power supply is actually capable of. I've seen a slew of AVR's that are rated at 140 wpc x 5,7 or 9 channels. In reality that is in 2 channels maybe. After 2 channels you could easily be down to 40-50 wpc with multiple channels running in a movie. Power supplies are the most expensive part of a receiver yet that is the first part they cut corners in. They are also not putting as big or many storage caps into modern receivers like in say the 90's.
    It you compared receivers from the 90's verses now the same comparable wattage multi-channel receivers will weigh drastically less that those 90's models.
  • I think my subwoofer handles much of the power sucking low end frequencies, and my 3.1 system is typically used to watch CNN or CBC News (god I'm feeling old now). lol
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    toolbelt wrote: »
    I had a powered subwoofer as well everything below 80hz went to the sub. I still blew drivers and tweeters. That is until I put the front three on a separate power amp. The rears usually can be okay on the receiver.
    Just an FYI, I'm not casting stones whatsoever. Please do not take it that way.
    I've opened so eyes when I ask folks to pick up my old denon 3805 that was 120x5 then ask them to pick up my 2 channel Aragon 4004 that is much heavier than the denon 3805.
    They denon still had 90 wpc running 5 channels.
    F1nut Posts: 51,996
    Those cause brain rot.
  • Also just curious if a malfunctioning crossover could blow speakers? Or would that just typically result in no power to the drivers or poor crossover function. Could a malfunctioning crossover boost the input signal to the point of blowing a woofer? If I replace the (3) blown drivers and known blown resistor, would these be as good as new, or do drivers typically have a lifespan at which point their performance degrades?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    F1nut Posts: 51,996
    Case in point...lol
    Give it up, they are not worth putting money into.
    Nope I wouldn't drop any coin into them.
  • What would be an equivalent model in the used market. I liked the RTI4's for their depth of sound in a small package. I don't need audiophile quality or volume output for my uses. Polk or Klipsch?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    F1nut Posts: 51,996
    The R200 would be my recommendation.
  • They're about 10x more speaker than I need. lol
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    F1nut Posts: 51,996
  • gp4jesus
    gp4jesus Posts: 2,019
    toolbelt wrote: »
    Polk RTiA 3 - next gen RTi4
    Same tweeter. Same size midwoofer w/similar voicing
    Similar dimension closure
    *all connected w/Premiere ICs
  • gp4jesus wrote: »
    toolbelt wrote: »
    So the RTIA3 is the more modern version of the RTI4's then?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    toolbelt wrote: »
    gp4jesus wrote: »
    toolbelt wrote: »
    Yes
  • halo71
    halo71 Posts: 4,638
    Infinity and JBL's were a vastly different experience, those needed shims for sure. They had much less clearance in the voice coil area.
    I've refoamed dozens of woofers over the years and never once removed DC or used shims. Including Infinity RSII, III and IIIa woofers. RS7B woofers and mids.
    --Gary--
  • gp4jesus wrote: »
    toolbelt wrote: »
    I've heard the model number before but assumed that the 3 was below the 4 in the pecking order, when, as you mentioned, it's an improved version of the 4's with a larger woofer. I read a comparison of the two models on here after you mentioned it, and it seems like the 3's are a noticeable improvement over the 4's. I will keep my eyes open as they sound exactly what I'm looking for.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    Correct. If my memory serves me well the RtiA9 is the improved Rti12 with a much better cabinet and XO.
    So all the RtiA models are the improved Rti line.
  • $225 Cdn for a pair of used RTIA3's in good shape with no cosmetic blemishes. Grills in perfect condition. Can test listen before purchasing. Fair deal? Anything I should look out for?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • gp4jesus
    I believe I misspoke or rather mis-posted. I’m sorry for all the stir my mistake caused.
    The RTi4 has a 5 1/4” or 6 1/2” mid woofer? The ‘A3 has a 6 1/2; the ‘A1 a 5 1/4.
    The ‘A3, per a reviewer, is THE largest bookshelf on the market - not a bad thing in the bass department. $225 I believe, is a good $ for an unblemished pair.
    Some Armacell on all smooth & shiny surfaces of the midwoofer is a very inexpensive ($5 @ Lowe’s or HD) and maybe an hour of your time. See my “ RTi A3s wall mounted as Surrounds.”
    https://forum.polkaudio.com/discussion/173492/rti-a3s-wall-mounted-as-surrounds#latest surrounds#latest
    The day they arrived… look at the pictures.
    Foam them per Gardenstater’s “Foam…” thread. You’ll already have the Armacell. This mod does require more patience but IME at minimum equally worth it.
  • The RTI4's have 5 1/4" woofers and 1" tweeters (silk dome) and the RTIA3's use a 6 1/2" woofer and 1" tweeter. The 3's are rated at 50-26,000 Hz and 20-150W and 89db vs the 4's at 60-26,000 Hz, up to 125 watts and 89db. Seems the main difference is better bottom end and more volume potential and 2"'s deeper and taller and 3lbs heavier. To get better performance out of my stand-in XT15's I've got my Subwoofer crossover set at 200hz but with the 3's I can probably reduce that to 100hz and let the 3's handle more of the bottom end load. My space is limited as I have my big screen in a corner with a fireplace on one side and a doorway on the other. The base of my bookshelf stands just squeeze in on either side of my tv stand but there is room at speaker height to squeeze in slightly larger bookshelfs. As for adding Armacell, I don't think CNN justifies the need. :)
    My 4's are set as small speakers in my AV. Would the 3's be the same?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • Ok change of plans. The first set of A3's I saw were in black/ash colour but I came across a listing in the Cherry for $15 more but located 40 miles closer, and still in the box. I prefer the Cherry and these are in mint condition, and with the price of gas and time saving, they actually work out cheaper. Stay tuned!! :)
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    F1nut Posts: 51,996
    Nothing does.
  • toolbelt
    toolbelt Posts: 124
    gp4jesus wrote: »
    toolbelt wrote: »
    Thanks for the heads up on the RTIA3's. I'm very pleased with them.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • toolbelt
    toolbelt Posts: 124
    Well to end this thread, although I replaced my RTI4's with a pair of RTIA'3, I was able to rebuild the RTI4's to their original state as follows.
    -sourced a used woofer to replace my blown one
    -replaced (upgraded?) both tweeters with Dayton ND25FN-4 silk domes
    -replaced blown resistor on each crossover with Mills MRA-5 2.5 ohm
    The total part costs were around $ 95, but shipping costs added another $60, and if I weren't fairly close to PartsConnexion, likely an additional $30 if I had required shipping. All costs in Cdn $$. They sound as good or better than the originals. Financially, because these weren't top end floor standing speakers, it's hard to justify the cost of repairing them, but I did it more as a learning experience. So I'm calling it even. :)0nu8acpf0c3r.jpg
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • gp4jesus
    I’m unfamiliar w/this phrase
