Where to buy a “male RCA cable to male USB cable.”
gp4jesus
gp4jesus Posts: 2,016
I want to connect a CD changer w/RCA digital out to a windows or Mac w/F USB in.
I have a CD/DVD player/burner w/a port…
…and a cord w/this…
…connector on one end & a M USB on the other. It works well as a player. So why not connect a CD changer w/a F RCA digital out?
I’m open to adapters but I much prefer a M RCA to M USB to minimize potential connection issues. If some (unknown to technical) issue would prevent this idea from working, I’ll “throw in the towel.”
As always, 1K thanks in advance for your help.
Tony
*all connected w/Premiere ICs
    VR3 Posts: 29,400
    I believe it's called a dac
  • rooftop59
    rooftop59 Posts: 8,121
    I don't think such a thing exists...why exactly do you need this?
    Game Room 5.1.4:
    Bedroom 2.1
  • Gardenstater
    Gardenstater Posts: 4,765
    Hey Tony, I think you're looking for a digital coax to USB converter. I'm seeing some that seem to do the reverse but I do not think they go the other way (not sure). My legacy iFi nano idsd has a digital coax output and USB input. Not what you need.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • invalid
    invalid Posts: 1,448
    You can go from USB to spdif(rca) with a converter, but you cannot go from spdif(rca) to USB.
  • newbie308
    newbie308 Posts: 800
    I'm not sure what you are trying to accomplish, but you could use the analog outputs from the CD changer and get an analog to digital converter that plugs into your computer's USB jack. It is the sort of device you would use to convert records to digital format. Like this:
    https://www.amazon.com/DIGITNOW-Capture-Grabber-Cassette-Converter/dp/B079CBGDST/ref=sr_1_3?crid=S98EGMJ8RJ13&keywords=analog+audio+capture+to+usb+converter&qid=1689620726&sprefix=analog+audio+capture+to+usb+converter,aps,148&sr=8-3
    audioluvr Posts: 5,885
    gp4jesus wrote: »
    Tony, what's with the latex gloves?
    Viking64 Posts: 7,520
    audioluvr wrote: »
    gp4jesus wrote: »
    The "male to male" part in the title probably has him concerned. :#
