How many tubes do you have in your rig?
Hello all and good afternoon to you all.
Just as the title states, how many tubes are you running in your system?
I'll start.
Lampizator DAC/PS - 4
Canary Pre/PS - 7
Jolida JD-9 MkII - 2
So, for my rig? At the moment, I have a total of 13 tubes that heat up the room quite well and offer me that great tube bliss.
What say you?
I may be wrong but I believe John has the most amount of tubes in his system simply because of his amps (from memory). Not that this is a contest or challenge....just curious.
If you don't have tubes...do you want to introduce them into the rig or are you satisfied with straight up SS?
If you do have tubes in your rig...do you yearn for more or have you found that sweet spot where you are content and just want to roll tubes from here on out?
«13
    pitdogg2 Posts: 27,423
    6 in the preamp
    In the power supply 1-5ar4, 1-6bq5 and 1-12ax7
    In the signal path 2-12au7 and 1-12ax7
    Toolfan66 Posts: 18,227
    edited March 2023
    9 Cary SLP-05
    3 OPPO-Mod Wright 205
    2 JD-9 Mkii
  • pearsall001
    pearsall001 Posts: 5,341
    None yet but I have 1 tube pre in house for a trial & picking up another one Sat to do a comparison. Having some fun 🎵🎵🎵
  • JayMX
    JayMX Posts: 460
    Just one tube here….
    The little Aiyima tube pre/DAC combo unit does surprisingly well with the tiny 5W class A ACA Mini driving the R200’s (despite their low-ish efficiency.) Fun to fool around with for sure. 😁🤘🏻
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
    mhardy6647 Posts: 35,306
    edited March 2023
    Five tubes, but two are twin triodes -- i.e., functionally, seven.
    The number goes up quite a bit when the MR-67 tuner's online.
    PS -- don't ask me how many there are in the house in toto, or even how many vacuum tube hifi components there are here. I do not know. I do even have one all vacuum tube television (a GE Portacolor!), and it sort of works, but not really. I can get a raster on it.
  • skipshot12
    skipshot12 Posts: 2,094
    Zero 😬
    Not ready for that pursuit at this time, damnit treitz.... 😳
  • stangman67
    stangman67 Posts: 2,330
    Six
    2 in the Modwright SWL9.0SE
    4 in the Modwright PH9.0X
    The more tubes the merrier!
    SCompRacer Posts: 9,128
    edited March 2023
    Audio Research Reference 3. 4 - 6H30 audio circuit. 1- 6H30 and 1 - 6550 in the power supply.
    Bottlehead Eros Phono. 2 - Telefunken EF86 first gain stage, 1- Amperex 7308 second gain and 1 - 12BH7 regulator. Yes, the Eros is worthy of the pricey tubes. :)
    Ten total tubes.
    Had tube amps before. Very happy with my Krell KSA-250 NPN bipolar SS amp. It gets toasty. Fortunately, the open main level with high ceilings doesn't trap the heat.
  • maxward
    maxward Posts: 1,721
    Jolida JD9 phono preamp: 2
    Eastern Electric M520 integrated: 10
    WOW!!! 3 JD-9’s in this thread…
  • displayname
    displayname Posts: 1,236
    6
    2 x ECC802
    4 x EL34
    Discogs
    heiney9 Posts: 25,545
    edited March 2023
    I'll play. The next question should be how many tubes do you own for all the tube gear in your house!?
    Eastern Electric - Avant Pre-amp
    (3) 12AX7/ECC83 - 1 pair of 1956 Tung Sol JTL 5751WA; single 1959 GE Gray plate for the balanced output which I am currently not using. So the tube is just a "place holder"
    (4) 12AU7/ECC82 - 1 pair 1955 Brimar ECC82 long black ladder plate w/sq getter; 1 pair 1960 Sylvania JHS Gold 5814 3 mica gray plate
    (1) 6X4 - 1959 Tung Sol JTL 6X4WA black plat "D" getter (rectifier)
    Eastern Electric - Mini Max Dac PLUS
    (1) 12AU7/ECC82 - Single 1957 Amperex Holland ECC82 long gray plate w/slant getter.
    That's the main rig. I still own (3) integrated tube amps w/power tubes 6L6 and 6V6. Driver tubes are 12AU and 12AX variants as well as 6SL7, etc.
    I have been trying to obsess less on tube rolling as the combinations are literally more than I have life left to try. So far the above combination has been the most enjoyable.
    As far as the dac, the Amperex went in the day I bought it and I changed it out one time for a 5814 GE tube, put the Amperex back in and it's been there ever since.
    In the dac the op-amps for the tube and SS output are socketed. I have upgraded all (4) with DEXA discrete Op-amps about 6-7 years ago. Made a huge difference.
    The rig has never sounded better.
    heiney9 wrote: »
    Oh God !! That's more than I want to type!!
    edited March 2023
    Right now I have enough tubes....meaning the right amount. I also own a huge stash to keep the rolling going if I so choose. I have found when I want to just change things up, sometimes just a different battery of tubes scratches that itch vs. buying something new.
    I will be replacing the awesome Pass Aleph 30 soon. It's been a trusted work horse and if you're a single ended class A guy, sounds superb. Moving on to the most current iteration in the same vein the Pass XA25.
    I was negotiating with a guy (buying an XA25) a couple weeks ago, asking questions, etc. $3.5K+ outlay person to person is huge deal to me. So I was covering all the bases and someone swooped in and paid him more than asking right as I was getting his PP info. I was annoyed, but that's how buying used gear on the internet goes it seems. Anyway sorry for going slightly off topic......
    heiney9 wrote: »
    I was thinking a round number......listing them all would take me until next weekend!
  • Emlyn
    Emlyn Posts: 4,839
    I used to have 26 tubes in play at the same time when I ran a Sonic Frontiers Line 3 preamp with a Sonic Frontiers Power 2 amp together. I suppose it could be 28 if the twin tubes inside a Musical Fidelity A5 cd player are counted. I no longer run tube gear although I do still have the Power 2 amp and A5 cd player stashed away. I preferred running the tube preamp with a solid state amp and the tube amp with a solid state preamp anyway.
  • invalid
    invalid Posts: 1,540
    I have only 7 tubes in my rig two 6sl7 in my preamp two rectifier tubes in the separate power supply one of my 866 rectifier tubes is from the 1920's, two 6sn7 in my dac and a 6x5 in the rectifier of the DAC.
    audioluvr Posts: 5,996
    2
  • ken brydson
    ken brydson Posts: 9,040
    I have a tube of Preparation H. Can I join the club?
    nooshinjohn Posts: 26,020
    18 tubes, with twenty KT120’s in reserve…
  • agfrost
    agfrost Posts: 2,477
    4 in my Hagerman Cornet 2 phono pre...
    Jay
    Clipdat Posts: 13,100
    treitz3 wrote: »
    Zero. Satisfied with solid state.
  • rebelsoul
    rebelsoul Posts: 758
    Bat mono blocks --24
  • rebelsoul
    In the process of buying a bat pre amp and that has 8 tube in it.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    37 total. 2 amps, 12 in each. Another amp (XAM receiver) has 13 in there I believe.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Osarion
    Osarion Posts: 193
    Conrad Johnson ET3 pre has 4, but 3 are phono stage
  • bcwsrt
    bcwsrt Posts: 2,553
    “Just” 9. But, hey, that’s 9 more than I had 6 months ago.
    12AU7 and 12AX7 recommendations from members here have me super-content at the moment. Time will tell what the future holds.
    Brian
    bcwsrt wrote: »
    Have you tried the AX7's I sent you yet?
  • WagnerRC
    WagnerRC Posts: 2,215
    edited March 2023
    Eighteen in the Joule Electra amp nine in the Cary none sure in the LA-300me
  • GlennDog
    GlennDog Posts: 3,158
    In with 28
    5 in the Lampizator DAC
    9 in the Cary 05 pre
    14 in Rogue mono blocks
    Sound is sooo good
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
