SRS-3.1tl
westmassguy
Sonicap Gen I Capacitors, Mills/Vishay Mills Resistors, Cardas Binding Posts, and Canare 4S11 Cable with Speakon Connectors. All components were removed from the boards. Inductors were measured and adjusted as needed. Boards were cleaned of excess solder and old flux. New connections and mounting holes were created as needed to allow the larger Metallized Polypropylene Capacitors to be installed.
Home Theater/2 Channel:
dhsspeakerservice.com/
Somebody's gonna get some great tunes. High quality on display. Hope you're doing well.Polk Audio first generation RTA-12s; 12 inch Polk Stands; DHS Speaker Service upgraded crossovers w/ Sonicap/Mills; the "westmassguy anti-lobing mod" (hyperdamped outer drivers/mirror imaged); tweeter anti-diffraction mod; Cardas binding posts; Neotech UPOCC internal wire; foam-lined inner driver baskets; xschop phase plugs; deleted fuses; Hurricane nuts; Sonic Barrier; Dynamat Xtreme
Thank you SirHome Theater/2 Channel:
dhsspeakerservice.com/ -
Beautiful!!!
Conradicles wrote: »Beautiful!!!
ThanksHome Theater/2 Channel:
Wow! Nice work.
Excellent work as usual Dave, I'm still enjoying the 3.1TL x-overs you built for me many years ago. The owner of those 3.1's is finally going to experience what they are capable of
Mike Reeter wrote: »Excellent work as usual Dave, I'm still enjoying the 3.1TL x-overs you built for me many years ago. The owner of those 3.1's is finally going to experience what they are capable of
Thanks MikeHome Theater/2 Channel:
