Polk Audio 5B bookshelf monitors
I just started using a set of Polk Audio 5B bookshelf monitors that were my Dad's in the mid '80s. Online reviews seem to be pretty good. My problem is that one speaker doesn't sound great, dull and not very loud. It was suggested that the tweeter may be blown. I bought a used one from the same era and swapped it in. It sounds better, the highs are more pronounced. The thing now is that the same speaker just isn't as loud as the other. I've changed the channels and connector wires, so that's not the culprit. I also tried new fuses with no difference. Any thoughts?
Answers
    pitdogg2 Posts: 27,349
    edited February 2023
    Since they have fuses, there could be corrosion either on the wires behind the block or the fuse holder. The fuse holder may not be readily apparent. Some use a pencil eraser to clean or maybe something like 2000 grit wet dry sand paper to lightly clean the fuse holder.
  • p8nberger wrote: »
    I My problem is that one speaker doesn't sound great, dull and not very loud. Any thoughts?
    Your problems may well be crossover-related.
  • gp4jesus
    gp4jesus Posts: 2,019
    XO cap refresh perhaps? Both speakers of course
    *all connected w/Premiere ICs
    Tony M Posts: 11,734
    Does the woofer cone move freely in the bad speaker?
  • slow_polk7 wrote: »
    p8nberger wrote: »
    I'm thinking so. I was looking for a schematic and believe I found one here: https://forum.polkaudio.com/discussion/38755/polk-audio-speaker-wiring-schematics-amp-more-all-models-except-sda The one labeled mb5_orig. My local audio guy is looking to see if the parts are still available.
    gp4jesus wrote: »
    Would this be different than the crossover? I'm still learning all the outs and ins.
    Tony M wrote: »
    I think it does, but I'll check to confirm.
    F1nut Posts: 52,012
    Not much of an audio guy if he doesn't know where to buy high quality caps and resistors.
    Here's two places to help you/them.
    https://www.soniccraft.com/
    https://www.partsconnexion.com/
    heiney9 Posts: 25,521
    There are also at least a dozen threads (or more) on upgrading the 5B x-over. I did mine years ago and since I used Photobucket to upload photo's, there are no photo's any longer on my upgrade thread.
