Crackling/Static Sound from both L800 Speakers
Just as the title states, I am getting a crackling sound from both left and right L800's... the noise is confined to the tweeters, and in a very narrow frequency range, so the noise can be every intermittent depending on the music choice. The noise sounds like the sound you would hear from an old television set when you were tuned to the wrong station or after a channel signed off for the night, but only in very short bursts when music happens to be in that frequency range.
The problem occurs in both speakers with music from a digital source and sent across RCA's to the Arcam. The problem does not exist over HDMI. I have eliminated the tube amps, DAC and SACD player, USB cables, RCA cables. HDMI out from my computer to the Arcam has no problems. I tested the speakers by using the L900 modules for test purposes, and the noise travelled to them as well. Unless I am missing something, it would appear that the computer is causing the issues or the Arcam is.
Do you guys see anything I may have missed?
    nooshinjohn Posts: 26,061
    I have also tested the SACD player into the same input as the computer uses, and the static is still present, so in my mind, that eliminates all sources and cables... the problem once again appears to be the Arcam....
    F1nut Posts: 52,144
    That was my first thought.
    Problem solved... There are settings for time delays within the Arcam, and those used for the CD input were not matched properly. Correcting this solved the problem.
    msg Posts: 10,532
    How do you go about determining the correct setting?
    msg wrote: »
    You just need to play around with it.
  • Emlyn
    Emlyn Posts: 4,866
    That's what she said.
    audioluvr Posts: 6,010
    Glad you got it solved right away.
    audioluvr wrote: »
    LOL... took me 7 hours to finally figure it out!
    mhardy6647 Posts: 35,364
    Gotta love technology. :#
    msg Posts: 10,532
    Emlyn wrote: »
    For 7 hours.
  • smglbrth
    smglbrth Posts: 1,500
    No school like the old school...
    smglbrth wrote: »
    dude...
    When we've got cracking static here, I know where it's comin' from...
    B)
  • stangman67
    stangman67 Posts: 2,330
    Always loved that Marantz table! So classy
