Say Hi and My Monitor 5b
First post here so just wanted to say Hi!
I came across this forum at the weekend whilst researching if a pair of Monitors were a good purchase ($15 at the local goodwill, one mid woofer has a small tear in it and 3 of the grill posts are broken on that same speaker and it had been glued to the cabinet!!! Also the dust cap on the other mid driver has been pushed in so needs to try pop that out!)
From a post here I worked them out to be the 5b, they're in excellent shape aside from the above few issues, I've ordered a used driver off eBay for $59 delivered but also plan to repair the one I have, so I at least have a back up.
I've been reading up on these and what modifications to do, for now I want to enjoy them in original form and plan upgrades from there (it appears some people like the tweeters but most don't, so we'll see how my old worn out ears feel about them! I'm by no means an audiophile!!),
Only thing I am going to do is some JB weld on the magnets to prevent any slip issues later down the line, just a little on the front and back plate to magnet joint correct?
Anyway thanks for listening
Ash
    F1nut Posts: 52,012
    Welcome to the forum.
  • Good score and ditto on the welcome to the forum!
    Keep that ripped mid. You might need parts from it one day.
    Looking forward to your opinions on the 5B!
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
  • Jazzhead
    Jazzhead Posts: 526
    Welcome. The "Search" function is your friend. Good find for $15.00, especially if you enjoy a project.
  • bcwsrt
    bcwsrt Posts: 2,520
    proudy202 wrote: »
    If you call "a little" a complete bead all the way around, then yes.
    Brian
  • skrol
    skrol Posts: 3,465
    Nice find. You can get the grill posts from Parts Express. https://www.parts-express.com/speaker-components/cabinet-hardware-speaker-grill-cloth/Grill-Guides-Grill-Frame-Kits
    I used the small for my Monitor5B.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    xschop Posts: 5,417
    Good Score. Fully modded, the 5B's are formidable for their footprint. Welcome to the rabbit-hole as they say.
