Polk Monitor 45B
Are Polk Monitor 45B good speakers?
Or are they just decent/average?
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
    F1nut Posts: 52,052
    45B???
  • RTiA5 + CSiA4 + Jamo SW410E
    No surround...yet
    F1nut Posts: 52,052
    Hmmm....never heard of those.
    xschop Posts: 5,484
    Looks like TSi style Polks. You'll have to do a foam-frame mod to those drivers and add sound absorption foam on the rear walls behind drivers to get them from sounding "hollow". That and a subwoofer, then they would be decent.
  • rooftop59
    rooftop59 Posts: 8,120
    French_guy wrote: »
    Definitely just decent/average. I owned the old monitor 40s and it looks like those are just an update. I would go for many used speakers over those, especially rt55is or even 25is. Of course if you’re getting them for super cheap they would be perfectly fine for a patio or garage type setup…
    Game Room 5.1.4:
    Bedroom 2.1
