Deoxit - Does anyone know...
    msg Posts: 10,650
    Meant to say - the speaker cables above weren't finished. I'd just thrown those connectors on to try out the cables.
    Typically finish with heat shrink to seal everything up and provide some strain relief, cable pants, and Tech Flex.
    msg Posts: 10,650
    hermitism wrote:
    I like to use DeoxIT® as lubricant.
    Deoxit G100L Off Label Use #27: Goldmember... for date night.
  • Keiko
    Keiko Posts: 807
    Gee Wally I've never used the aerosol product, I've only used the 100% products that you brush on or has a needle applicator. It's super easy to control unless you knock the bottle over.
    Hey, Wally! Why should I wipe my behind? I'm only gonna go again anyway.
