Seriously!?!?...
Just gave my beat up Monitor 7b's some much needed attention. Along with all the normal mods I also replaced the vinyl wrap with veneer, rebuilt the crossovers, and installed some front to back cabinet bracing. Everything was going smoothly and then this happened! Seriously!?
I guess in my attempt to make sure everything was sealed as tight as possible, I over torqued the screws. Definitely won't seal properly with that piece broken out. The plastic is 40 years old too, but obviously it was my fault.
I made a couple of plates out of 16 gauge steel as a temporary fix while I try to find a replacement, but they might just stay though. They look decent and are definitely functional. Plus who looks at the back of a speaker anyway?
  • Gardenstater
    Gardenstater Posts: 4,862
    Hmm. Pretty dang close to where the braces are located.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,682
    Hurricane nuts and threaded bolts, torque them down and your cabinet will also stiffen/strengthen there.
  • Jazzhead
    Jazzhead Posts: 526
    Don't feel bad, not your fault. Mine (1980) had disintegrated around most of the screw holes without being touched. I replaced mine with custom fabricated aluminum discs and Cardas posts.
  • subkron
    subkron Posts: 82
    I had the same issue about 4 weeks ago on one of my 7Bs. My fix was my son 3d printed out a black "ring" about 0.09" thick and I used jbweld to epoxy the ring to the plate inside surface. Drilled out for screws, then screwed the plate on at the broken areas with longer screws and a large flat washer to capture the remaining plastic. Seems to work well for me, at some point I will look to replace the plate as well.
  • BlueBirdMusic
    Does this imply we are ALL getting OLD?
    Harry / Marietta GA
