Monitor 7 Stands
Bugtussle
Happy New Year to all here. I've been looking for some stands for my Monitor 7's. I really like the looks of the metal stands that go with the new KLH Model Five and think they would be a perfect fit. I can't spent $350 for a pair of stands though. Can anyone recommend a similar and more affordable solution?
https://crutchfield.com/p_405M5RISER/KLH-Model-Five-Riser-Base.html
If you do a search, you’ll find plenty of plans in the archives here so you can make your own for the M7’s just like the originals. Pretty easy and inexpensive
bugtussle...I too like the look of those stands for the klh speakers... if you are capable of wood working, I bet you could make those out of wood...M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters -
Thanks for the suggestions here. It looks like I will put something together myself.
Polk Stand:
Home Theater/2 Channel:
dhsspeakerservice.com/ -
I recall there used to be an old thread on the forums had the various Polk Audio Monitor stands with measurements.Stan
Main 2ch:
HT:
Other stuff:
I may have found it (pdf file) and some other info that I tucked away.Stan
Main 2ch:
HT:
Other stuff:
