Polk Magnifi Mini AX DSP issue
cookiehank
Hi there, is there anyway you can listen to the AUX input without any DSP processing ie. Without any of the sound modes to avoid sync issues using multiroom devices?
Hello,
There doesn't seem to be a "direct audio" setting, here are the available modes:
Maybe try using the "delay" function to correct for any timing errors? Just a thought. -
My Polk Woodbourne Won't Turn On
I think there's a pill for that.
SeleniumFalcon wrote: »Hello,
Unfortunately, because the AUX input is going through a DSP, that causes the delay. Using the delay function will only increase the issue. Thanks for reply though. -
Hallo
Habe mir die magnif mini ax gekauft,
Habe probleme mit ton aussetzer bei aux Eingang! Habe auch verschiedene aux kabeln ausprobiert, alle haben das gleiche störung! Was kann ich machen?
Software Update ist installiert!
Danke vorraus. -
Translation:
Hello
I bought the magnif mini ax
I have problems with sound dropouts with aux input! I've also tried different aux cables, they all have the same problem! What can I do?
Software update is installed!
Thank you in advance. -
Hallo,
Ich werde einen Freund bei Polk Audio um Vorschläge bitten.
Hello,
I will ask a friend at Polk Audio for suggestions.
