New speakers for the man cave
13»
    Clipdat Posts: 13,105
    Leave them playing at low levels with an FM tuner (or internet radio station, etc.) while you aren't actively listening, it'll dramatically speed up the time necessary to break in the crossovers.
    msg Posts: 10,650
    10 hours?!? what?!?? you POSeur!!!
  • hochpt21
    hochpt21 Posts: 5,423
    msg wrote: »
    I know I know….
    Busy time for me so I don’t get a lot of dedicated man-room time :#
    msg Posts: 10,650
    haha, that's alright, apparently we're all making up your slackery.
    these things are pretty great, though.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Well, yesterday I proved to myself once again how much of a dumba$$ I am. The Linton's were kicking it right out of the box, clean, clear airy top end...and then after around 40-50 hours they went dull on me. Treble just took a big step back and turned very 'mellow', I just figured they were still running in and this is part of the process.
    I hadn't removed the grills since receiving them, until last evening and soon realized the tweeters were on the outside of the cabinet instead of the inside. I removed the speakers from their boxes which were marked R & L and setup accordingly...but, I didn't bother reading the Manual when I set them up, I mean who does that ;)
    The Manual clearing states that "Tweeters need to be on the inside and the Grill Badges on the outside" switched the Linton's around and everything came back into focus and the treble is back and the imaging correct once again B)
    So, I'm going to blame this one on the poor guy in the factory that puts these in the boxes :D and not because I'm a dumba$$
    msg Posts: 10,650
    Not just you, Mike. In my excitement, I lost track of which was which after unpacking, thinking there'd be an R and L on them. Noht. Read that grill badges bit three times looking back and forth before being satisfied I had them right. I was able to see behind the grill with a flashlight to see that the tweeters were inside to double check myself :)
  • Mike Reeter
    I rolled a different tube in the DAC and the center image is returning to where it was previously, the clarity and air, yet rich presentation is back. Also turned on the Subs to accompany the low end.
    Been working on placement, where I think I've finally found the sweet spot, raised the front of the stands to help elevate the image a tad bit. The Linton's are sounding the best they have since I originally set them up.
    Guessing around 90-100 hours in and I'm grinning :)
  • Emlyn
    Emlyn Posts: 4,920
    I wasn't expecting to see this but Wharfedale decided to put out a three-way center speaker to match the Linton and Denton main speakers in each of the three cabinet finishes:
    https://www.crutchfield.com/p_336HRTGCRM/Wharfedale-Heritage-Centre-Red-Mahogany.html
    pitdogg2 Posts: 27,914
    Nice looking center!
    msg Posts: 10,650
    Funny timing on this, @Emlyn - I just noticed this on Crutchfield the other night, myself, while poking around the Wharfedale line.
    Does kinda have me thinking about whether to move from the 706c to a matching Wharfedale center for the Lintons, but I have to say, the 706c doesn't seem a glaringly poor match? Maybe a case of not knowing what I'm missing until I hear it?
  • Emlyn
    Emlyn Posts: 4,920
    I have used a 704C with my Lintons and found it to be a very close match. Unfortunately, the new Heritage Center's cabinet is about an inch too tall for where I could use one. Fortunately, it'll help me justify not spending $1K to buy one. :)
