Parasound JC5 amp + Polk L800 speakers
Is the Parasound JC5 amplifier a good match for the Polk L800 speakers? Is it compatible (and ideal) for SDA?
Answers
    pitdogg2 Posts: 27,689
    edited November 2022
    Your best bet is to call Parasound and ask if it is a dual differential amp and common ground. If it is dual differential it is not a good candidate
    I know several here use the A21/A21+ on older SDA speakers.
    nooshinjohn Posts: 26,087
    Common ground is no longer an issue.
  • Emlyn
    Emlyn Posts: 4,888
    A forum member checked with Parasound directly on the JC5 and was told it is compatible with the L800s
    I have a JC5 but don't use it with my L800s. I wouldn't have any concerns if I did. I instead use it with a pair of JM Lab Electras.
    Is it ideal for the L800s? Don't know as that'll depend on what an owner wants. I can say that it is quite a bit different in sound signature and performance than a standard Parasound design like an A21, A23, etc.
