SDA 2b and DENON PMA-2000R
  • Schurkey
    Schurkey Posts: 2,130
    skipshot12 wrote: »
    From reading I can assume my blade/blade are not compatible?
    WHICH "blade/blade" speakers are you talking about?
    Blade/blade SDA 2B, and blade/blade SDA 1C can be made compatible with a piece of wire and suitable connectors. SDA 2A and 1B, and earlier versions, cannot.
  • skipshot12
    skipshot12 Posts: 2,164
    Schurkey wrote: »
    skipshot12 wrote: »
    SDA SRS
    F1nut Posts: 52,406
    edited October 2022
    Depends.
  • skipshot12
    edited October 2022
    Depends.
    SDA SRS with serial # greater than 5001 are compatible with the AI-1?
    I shall take another look at my serial #’s…..
    I do know that my drivers are all dated 1986.
    Looking at the sda lookup I think my sda srs are version 3?
  • skipshot12
    Looks like no Dreadnought here...
    Serial #'s in the 3000's.
  • Unknown
    edited October 2022
  • alexanikin
    Pin/blade models only the pin carries the signal and the blade is for support or connection of ground for mono blocs or non-common amps.
    This is something that caught my eye. My 2B's didn't have an interconnect cable, so I made one connecting speakers only over pins. Two questions:
    1) is there a need to add a wire for blades too? (in case of amp with common ground)
    2) would it be helpful if Denon actually have no common ground?
  • Unknown
    edited November 2022
  • alexanikin
    Hey everyone. Thank you for all your thoughts here in this thread. It turned out that the unit I wanted to get have problems with its faceplate, so I decided to pass. So in this thread, there is will no answer if its common ground or not :)
  • DarqueKnight
    Why a Dreadnought works so well with common ground amps I cannot explain either but it does and many have confirmed it in spades. I used one on mine with my Carver TFM45, it made a pretty significant difference.
    The ground plane of an amplifier is a significant reservoir of electrical noise. The Dreadnought allows you to bypass that. Electrical noise has a particularly detrimental effect on the spatial properties of an amplifier, as well overall clarity and detail.
    The amplifier interface one (AI-1) cable had a small box built into the cable that had a tiny torrid transformer built into it. Research of this tiny transformer with the help of Matthew Polk lead to the development of the larger much better torrid transformers 800va-1000va dreadnoughts. @DarqueKnight provided the in depth research and development and named them dreadnoughts.
    I am not aware of any original AI-1 interfaces that used a small toroidal transformer. The AI-1s I have seen and read about in Polk's literature, and the AI-1 that I own, uses a tiny laminated steel transformer that is prone to saturate and increase distortion in the music. Matthew Polk advised using a non common ground interface based on a large, high current toroidal transformer. Large, high current, low-noise toroidal transformers were prohibitively expensive during the SDA era. High current, low noise toroidal transformers are still expensive.
  • Unknown
