BBQ Ribs on a Propane Grill
kevhed72
Any hints, tips, or tricks to do this? Want to try something different for the 4th. I know charcoal is optimal but that's not happening....thanks!
I've cooked ribs on a propane grill. Not much is different, no direct heat. Heat on one side find a sweet spot of 250° and let them go. Mist or bast every 40-45min. If you want to wrap do it the last hour or so. At that point a small flame (low) and temp no more than 300° for the last hour. Wrapping can make for a softer exterior, so if that is your bag do it.
Takes about 4-5 hours and yes I use a probe thermometer to monitor the temps. At 200°-210° I consider them done. -
This is good advice! I use to use a Weber spirit 310 I think, three burners - front, middle and back. I would only light the back burner, and additionally for truly indirect heat, get a big disposable tin casserole dish and fill it about halfway with water (refill as necessary during cook). Put that below the grates between the flavorizer bars and the grates. Put your ribs above the water pan. Also, if you keep the temp between 225 and 250, you can smolder wood chucks for some smoke flavor. I would just put hickory or apple wood chucks directly on the flavorizer bars.
Also, if you wrap, take them off, take out the water pan, crank up all the burners, brush your favorite sauce on ‘em, and caramelize that sauce and crisp up the skin. Makes them extra tasty!
Here’s where I learned how to do this: https://amazingribs.com/more-technique-and-science/grill-and-smoker-setup-and-firing/how-control-temperature-indirect/Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
On my Weber I turn the outside burners on low and cook ribs in the middle (lid closed/indirect heat) wrapped in aluminum foil with a little salt and pepper and a quarter cup of water for about an hour per pound. Then take them out of the foil and baste them in your favorite bbq sauce until carmelized.Gustard X26 Pro DAC
All right I’m going for it….was able to fit 3 whole slabs cut in half on the new Charbroil. Pics of the finished product coming in about 5 hours!
Do not get a discouraged if these don't turn out right it usually takes three or four times before you find the sweet spot how your grill is going to cook them.
Less prep time before the feast is a plus in my book.
Soon the tree-huggers will come out with a Tesla grill because gas is bad ya know.Don't take experimental gene therapies from known eugenicists. -
Nothing like mixing politics into a thread about BBQ lol. 3 hours in I flipped and rotated all 6 half slabs. At this rate they should be ready at 8pm! The grill has been consistently at 250 with the one burner on….in a couple hours I will be tempted to fire up a 2nd burner.
I have a different approach, wrap them in foil, put them in your oven, low and slow like 225 for a good 6 hours. Then unwrap them ,toss on the grill with your favorite sauce for about 10 or 15, and they will have a nice carmelized outside and soft falling off the bone meat.HT SYSTEM-
lsi 9's -
What smoke? Why do you always see smoke?Gustard X26 Pro DAC
anonymouse wrote: »
Not on a gas grill.Things work out best for those who make the best of the way things work out.-John Wooden -
They turned out better than expected butt a bit on the dry side, probably because I had to fire up a 2nd burner to 350 the last hour or so. Otherwise, we would have ate at 10pm. Most important part I learned was start cooking at 11am next time....overall, a success.
I find it usually takes 4-5 hours and unless wrapped you'll need to mist your favorite basting sauce or juice. I water down some apple juice or BBQ sauce depending on the food. I try to mist every 45-60min.
I'm glad it turned out good for you. -
On charcoal I can go as long as 7 hours…so definitely want to start around 11 normally.
Mine usually are fairly dry and crispy on the outside, but pretty darn perfect on the inside. I usually baste with bbq and then open the vents and crank up the temp and caramelize that sauce for about 5 minutes a side before serving. For me that’s the perfect combo of textures and flavors…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
anonymouse wrote: »
Not on a gas grill.
here's what you use for smoke flavor.
https://www.amazon.com/Skyflame-Universal-Stainless-Charcoal-W-Shape/dp/B07MDPFK8H/ref=sr_1_4?crid=2J9FQAIHZD07H&keywords=wood+chip+box+for+gas+grill&qid=1658387690&sprefix=wood+chip+box,aps,145&sr=8-4Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Need to BBQ the bots that keep showing up in this thread.
Brian -
As well as the two bots that clicked Insightful.
Will a 5th member please click the spam button and make the smucks disappear.Political Correctness'.........defined
President of Club Polk -
anonymouse wrote: »
Not on a gas grill.
Who flagged Marvin’s reply? HahahaThings work out best for those who make the best of the way things work out.-John Wooden -
anonymouse wrote: »
Not on a gas grill.
One of the bots?Political Correctness'.........defined
