SWA500 Subwoofer Amplifier Unexplained Failure
There are posts about this, but from ten years ago.
My in-wall subwoofer and its SWA500 amplifier has worked from when this house was built in 2015 until now. I noticed it was not participating. I tested the driver by injecting a powered signal to the cable normally attached to "speaker out" and sound is produced. I attached this same powered source to the "speaker in" (with the driver reattached to "speaker out") but no sound produced. Power seems to be fine, and the power LED shows either red or green (green if I flip from "auto" to "on"). The normal configuration is a single connection from "sub out" on the receiver to "LFE IN (unfiltered)". But since my "speaker in" experiment produces no sound, I am going to assume that the receiver itself is not likely at fault and that it is the SWA500 that has failed.
Has anyone here experienced this?
What is the likely failure in the unit, and is it something that the repair center is likely to be able to fix?
The apparent price for this thing is around $650 (it came as a package when I purchased the sub itself), which I will spend if I have to but would prefer not. I wonder which Polk product would be a suitable substitute, though? I am pondering a stand-alone unit that I can hide behind a chair (this option was not apparent while building the house).
I am aware that this is a fuzzy question. Just wondering if anyone has solved this cheaper than the $650 solution... or has other insight.
Thanks!
    VR3 Posts: 29,626
    In wall subs usually need the associated amplifier versus an off the shelf option. They usually have equalizers and such built in
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,340
    I recommend sending an email to: Kim.Jasper@soundunited.com he can let you know the options available.
  • rooftop59
    rooftop59 Posts: 8,120
    klosset wrote: »
    Thanks!
    If you can put it behind a chair or someone else in the room spend your $650 on something different:
    1. https://hsuresearch.com/products/vtf-2mk5.html - $780 shipped
    2. https://www.monoprice.com/product?p_id=42843 - $650 shipped
    3. https://www.svsound.com/products/sb-1000-pro-subwoofer - $600 shipped
    Game Room 5.1.4:
    Bedroom 2.1
  • WLDock
    WLDock Posts: 3,073
    edited May 2022
    klosset wrote: »
    Thanks!
    Take a look at this post here: https://forum.polkaudio.com/discussion/184595/swa500-amplifier-sudden-zombie-mode
    The SWA500 Polk amp is a 500 watt BASH amp with built in EQ for the CSW100, CSW200 and CSW155 in-wall subs. I've tried to repair one but it was too badly burned however, some have had success the post repairing the amp and BASH amps in general.
    After looking at post above, if you are inclined, open the amp up and see if there are any signs of burned components. If you have a local electronic repair tech maybe you have have it repaired for not too much money.
    Another option is to just replace it with a basic 500 watt plate amp and use your receiver's bass management and/or DSP unit like a miniDSP to adjust the bass response.
    https://www.parts-express.com/speaker-components/subwoofer-plate-amplifiers
  • klosset
    klosset Posts: 2
    Thanks all for the helpful comments. I found a "TV Repair Shop" (which was a sole proprietorship operated by a nice, old, foreign, electronics enthusiast) that was full of vintage tube audio equipment and other cool stuff in addition to TVs. He replaced the capacitor(s) that others have mentioned on this forum and the unit is functional again. I mainly post this as a documented case of a successfully repaired SWA500.
    The cost was $150 of which $30 was a non-refundable up-front charge.
  • WLDock
    WLDock Posts: 3,073
    edited May 2022
    klosset wrote: »
    Glad I could help! Another amp saved from a landfill!
    Now, I need to get busy repairing my own pile of old amps.
    The repairs never stop. I just repaired my Harmon Kardon bluetooth speaker, now I need to order batteries for my AKG wireless earbuds.
