Does Increased Wattage Change Tweeter Sound?
  • Schurkey
    Schurkey Posts: 2,122
    gp4jesus wrote: »
    “A single, double-wound transformer is essentially the same as two separate transformers on a single iron core.”
    So you claim the Belles 350 transformer shares only a single core and a power cord. Each channel’s “power supply” has its own set of primary windings in addition to each having secondary windings.
    I don't claim anything in regard to the Belles 350. Never heard one...never seen one.
    All I know is that the 100 watt version from my favorite amplifier manufacturer uses a double-wound transformer, while the 200 watt version uses double transformers, and each with separate power-supply capacitors, rectifiers, etc. Both of 'em claim "Dual Mono" status.
    VR3 Posts: 29,627
    I believe there comes a point with to much power sparks and flames shoot out, atleast that is what I have heard.
    mhardy6647 Posts: 35,374
    edited May 2022
    VR3 wrote: »
    Although a well designed crossover should fall on its sword and immolate first, to protect,say, an expensive beryllium dome tweeter.
    It is well established that a $500 power transformer will usually fail to protect a 20-cent fuse. This is called engineering. ;)B)
    (EDIT: Note that I am being facetious. Mostly. :#)
    VR3 Posts: 29,627
    Psshhh, flames out of the tweeter are 2ay cooler than burnt resistors
    edited May 2022
    VR3 wrote: »
    This raises an important question.
    Does a waveguide* tend to focus or to disperse the flames?
    Discuss.
    :D
    _____________
    * Pretty much the same thing as a horn, but it costs more. :#
  • gp4jesus
    gp4jesus Posts: 2,019
    Schurkey wrote: »
    “..,the 100 watt version from my favorite amplifier manufacturer uses a double-wound transformer, while the 200 watt version uses double transformers, and each with separate power-supply capacitors, rectifiers, etc. Both of 'em claim "Dual Mono" status.
    Works for me😊
    *all connected w/Premiere ICs
