Is it a good idea to use S 35 Polk as centre & front speakers
I am trying to build 5.1 surround system in my bedroom. I have some shortage of space & so considering S35 as centre, front right & left speaker. Rear shall be S 20 or S 15 speakers.
Pls let me know if its great combination. If this S 35 is not the best choice then with some civil work I can manage to put S 20 on both back & front. Use S 35 only as centre speaker.
Please help out to get the best of the home theatre experience.
Thanks a lot folks.
    F1nut Posts: 52,241
    edited March 2022
    The C, L & R receive a separate dedicated signal, therefore you cannot feed 3 separate channels into one speaker.
  • ken brydson
    ken brydson Posts: 9,072
    I think he was proposing using 3 S35's for his front stage. I'm using an S35 for my center. The manual mentioned mounting them vertically to use as mains. How it would sound, hard to say.
    F1nut Posts: 52,241
    He refers to the S35 in the singular.
  • polrbehr
    polrbehr Posts: 2,865
    It almost looks like he thinks the S35 can be used as a surround bar type speaker?
    I also have a S35 center, but cannot comment on how it would perform as L & R channels but why not? Using them [mounted] vertically should be fine, just would not expect much in the way of bass without a separate sub. My $.02
  • rooftop59
    rooftop59 Posts: 8,120
    kapil29 wrote: »
    Thanks a lot folks.
    3 front speakers or 1? 1 will not work so good…
    Game Room 5.1.4:
    Bedroom 2.1
