I have the Tsi 100, and my tweeter quit working.
I pulled out the tweeter and connected directly to speaker wires, and it worked great. What else can I do?
Answers
  • boston1450
    boston1450 Posts: 7,758
    edited March 2022
    Probably a wire issue or crossover issue. Take a look. Check connections inside. You could also swap around tweeters & see if it works on other cabinet & then youll know for sure if it's a wire issue or a crossover issue. Report back & someone will chime in.... welcome to the forum
    Post edited by boston1450 on
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • MikeUp
    MikeUp Posts: 86
    Sounds like a bad cap in the crossover or a cold soldier joint on the crossover board.
    Good luck
    On to new and better adventures
    pitdogg2 Posts: 27,486
    It could also be a fried resistor, $5 and back in the game.
