CD Player Recommendation
Went full digital and then unearthed my CD collection. Looking for a decent CD player, new or used for less than 300-400$. Recommendations?
2Ch Tube Audio Convert
  • jbreezy5
    jbreezy5 Posts: 1,141
    NEW:
    • Cambridge Audio AXC35 CD Player
    • NAD C 538 Compact Disc Player
  • Nightfall
    Nightfall Posts: 10,083
    If you want modern amenities another option is something like Cambridge CXN V2 and just rip all your CDs to FLAC, EZPZ no more disc swapping
    afterburnt wrote: »
    Village Idiot of Club Polk
  • jbreezy5
    • Yamaha CD-S303
  • If you can find one used.
    oppo bdp-103
  • smglbrth
    smglbrth Posts: 1,497
    My son recently bought an Onkyo C-7030 and is super happy with it...
  • sparky14
    sparky14 Posts: 23
    Hey, I did that too. After a few years of all digital, I happened upon a 90s JVC CD player at a thrift shop for $10. Unfortunately, that got me back into physical discs. The old JVC looks, works, and sounds great. I highly doubt anything new would be significantly better.
    Somewhere along the line, I noticed I had 50 or so HDCDs, and a dozen SACDs, and a few DVD-As. So back to the thrift stores and ebay bargain hunting I went. So now I have...
    JVC XL-Z431 for standard CDs.
    Marantz DV6400 for SACDs and DVD-A.
    Toshiba SD-9200 for HDCD and DVD-A.
    Polk R200 SpeakersSchiit Saga S & AegirCr*pload of old disc players for my old CDs.
  • rooftop59
    rooftop59 Posts: 8,120
    sparky14 wrote: »
    The sound quality can get a LOT better, but glad you are happy…
    Game Room 5.1.4:
    Bedroom 2.1
    F1nut Posts: 51,943
    A helluva lot better!
  • Emlyn
    Emlyn Posts: 4,811
    That Toshiba SD-9200 is an excellent CD player as long as it works. Was an easy fix if one developed the transport vibration.
  • rooftop59
    edited May 2022
    That JVC has a one bit DAC…now if your just using it as a transport to an external DAC, it might be okay. If your using the internal DAC you are missing out brother…
    Emlyn wrote: »
    Sam thing with this one…probably a better transport, but the DAC is still light years behind.
    Game Room 5.1.4:
    Bedroom 2.1
  • sparky14
    sparky14 Posts: 23
    Wow, lots of audio snobs! Thanks for pooping on my players. I thought I liked them all, but I'll go throw them in the trash.
    And yes, I also use Monoprice cables. There, lobbed it up for you, go for the slam.
  • rooftop59
    sparky14 wrote: »
    No **** man, you just said that you doubt anything would sound better than the JVC…this is an audio forum after all. What else else did you come her for other than discussion of audio?!?
    Game Room 5.1.4:
    Bedroom 2.1
  • sparky14
    sparky14 Posts: 23
    No problem, you got me. I've also got a Nobsound Tube amp coming. Slam away!
    F1nut Posts: 51,943
    edited May 2022
    Stick around, we'll educate you on how to get better sound if that is of interest to you.
  • sparky14
    sparky14 Posts: 23
    Thanks, that is why I am here. I still like my 3 players that cost me a combined $85.
  • PSOVLSK
    PSOVLSK Posts: 5,398
    sparky14 wrote: »
    My advice: Take your wallet and don’t ever come to this forum again.
    Just kidding…sort of.
    F1nut Posts: 51,943
    sparky14 wrote: »
    It's fine that you like them, but stating you doubt a newer CDP could sound better when you haven't heard any isn't helping your position.
    No one cares how little or how much your gear cost.
  • marvda1
    marvda1 Posts: 4,960
    @sparky14 where are you located? get out and listen to as much audio gear as you can. see if there is a group of guys into audio that get together for meets.
    Puritan PSM156
  • sparky14
    sparky14 Posts: 23
    marvda1 wrote: »
    Thanks marvda1, I've been really into this in the past. 25 years ago back in Kansas I had the dedicated audio room with Martin-Logan/Rotel/Luxman. But I moved to California, and you don't quite get the space here that you get in Kansas. I do still go to the LA Audio show every few years, it is a blast to see and hear the megabuck equipment in action.
    But now my audio space is my work desk, and the Reserve R200 serve quite well there. But I am an old guy now, and while I can hear difference between a $10k system and a $1k system, MacArthur Park still sucks on both of them. It takes proper positioning and room treatment for me to really notice the details, and I don't choose to put that much effort into audio. Nor do I deride the people that do want to invest more, as I have been there and it is a fun ride when you hear what a good system can really do.
    Yes, I know there is much better equipment than what I have. But in my setup, I am not going to hear those differences, or they are not going to be significant enough that I would care. But I can still enjoy what I have.
  • sparky14
    sparky14 Posts: 23
    Emlyn wrote: »
    Hey Emlyn, my SD-9200 does have a slight vibration issue for the first 15-20 seconds. Happens to about 1 of 5 discs. Goes away quick and can't be heard when the music starts. Still, I'd like to fix that. Do you know where I can find info on that easy fix?
  • Milito
    Milito Posts: 2,003
    sparky14 wrote: »
    marvda1 wrote: »
    I understand where you're coming from as I wear hearing aids. I'm 71and I wondered if I should spend the money on nicer audio gear when I came back to this forum as I spent many years away. Mainly in the car audio forum.
    I can tell you I can hear the difference in upgraded audio gear, maybe not as much as some of the younger people here with much better hearing. However it's worth it to me, but if it's not to you I understand.
  • sparky14
    sparky14 Posts: 23
    Sorry to the OP as this seemed to veer off to a discussion of my players. I'll repost your question and hopefully get some discussion focused there.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,806
    Here is one for you that was just reduced by $100: Price is $500 + $38 shipping.
    Marantz CD6007 audiophile cd player Highly Rated Superb Quality
    https://www.usaudiomart.com/details/649856783-marantz-cd6007-audiophile-cd-player-highly-rated-superb-quality/
    Harry / Marietta GA
  • Emlyn
    Emlyn Posts: 4,811
    sparky14 wrote: »
    Emlyn wrote: »
    The problem with these was the rubber dampers failed on the transport mechanism. Recommend searching on Google for “SD-9200 fix” but I don’t know if the repair kits are still available.
    xschop Posts: 5,341
    smglbrth wrote: »
    My C-7030 has been a reliable workhouse for over 4 years now.
  • sparky14
    sparky14 Posts: 23
    Thanks @Emlyn, it does look like that damper kit availability is long gone. Hopefully my SD-9200 continues with just a small rumble for a bit, it is amazing otherwise. I'll use it until it dies.
