Schiit Freya + w/NAD M51
So my current setup is Auralic Aries LE - NAD M51 - Parasound HCA2200ii - Polk L200
Never owning anything with tubes but looking for an upgrade to the preamp, and have read and watched a ton of great reviews on the Schiit Freya + to go along with the price range I can swing. I’m hoping to get that large sound improvement like I got when recently upgrading my speakers.
I guess my question is, does anyone have any experience with the M51 then upgrading pre/dac, or owning the Freya+ ?
Also how would that work, using just the DAC to the Freya? Just somehow turn off the preamp section of the NAD?
I’d possibly look into a DAC change after that, unless it sounds great w/m51.
Thanks!
    pitdogg2 Posts: 27,368
    FWIW That tube hole is deep.....VERY DEEP
    Cheap tubes are no good and good tubes are not cheap...
  • rooftop59
    rooftop59 Posts: 8,120
    Thanks!
    I loved my m51, and never used it as a pre, just a DAC going into an integrated amp. Easy to set it to fixed volume, just look in the manual or online.
    I have no experience with the kinda schitt to which you refer…
    Game Room 5.1.4:
    Bedroom 2.1
    Clipdat Posts: 13,100
    The NAD M51 appears to be an excellent unit with capable pre/volume control functionality. I believe you would get more benefit by upgrading your amplifier. Benchmark AHB2 if you can swing it.
