SR2 Pairing Issue
SeafleaXT
When I paired my SR2 rear speakers with my Magnifi 2 the first speaker went to a solid green light. This is correct. The second speaker went to a solid yellow light. This is incorrect. Both speakers seem to be working but I can’t tell if the incorrect speaker is just playing what the correct speaker is playing or if the are indeed playing as separate channels. Is there a way to factory reset the rear speakers so I can retry the setup or is there something else I can try?
Answers
From reading the owners manual I believe you are just using the multi speaker function of Chromecast, not separate channel surround sound.
No I'm talking about the pairing lights on the back of the SR2 rear speakers. These are the lights that show if they are paired to the soundbar and will be on regardless of the mode your in and even when the system is off.
I recommend send an email to: Kim.Jasper@soundunited.com for assistance.
