Intermittent sound on Center Channel
Hello,
I have this recurring issue with my center channel speaker, which is the CS1 monitor series II. At times when I start a new show, the center channel sounds low, off or muffled until I turn the volume up to a ridiculous levels, which then "pops" it and results with the normal sound coming back.
I've checked the speaker cables several times and made sure they're firm and intact. Any suggestions?
Answers
    audioluvr Posts: 6,010
    Do you have another speaker you can replace it with temporarily just to see if the source is your AVR or the speaker?
  • Unfortunately I don't have another spare speaker to try out, but I'm open to other suggestions.
    Thanks.
    VR3 Posts: 29,627
    Pretty sure you have a dieing channel in your amplifier. You can swap which speaker is connected to that channel to confirm
