Greg MacDonald
bikerman
My polk s2 sound system not working on new insignia tv. everything is hooked up correctly and have solid green lights on system. What could be the problem? I also have the tv set for optical'
Answers
Hello,
You are using a Toslink digital optical cable, correct? Or, are you using an HDMI digital cable? -
I'm using the optical cable that came with the system.
The LED display on the bar should look like:
My display has just the white (or clear) optical light showing...
Let me check with a friend at Polk.
His response:
"Have them confirm that the internal TV speakers are disabled.
If they are, have him reset the TV and bar. It looks like the bar is receiving an input signal."
Thanks...I will try that
