Polk DSW Pro 660 constant static/hum
ziggy1971
Hi,
My Polk DSW Pro 660 recently started outputting a constant static/hum sound.
I disconnected the LFE line input from my receiver and the sound still remains. The sound increases/decreases with the volume control.
The sub is no longer under warranty so that is not an option.
Any ideas as to the cause of the static/hum?
I read on some sites that it may be related to a ground loop issue with other components in the system, but I haven't tested/tried anything because I don't want to make things worse.
Thanx in advance.
Thanx in advance.
Answers
I had a similar issue on my DSW 660 Pro wireless. Pulled the amp out and it was a mess. Lots of discoloration and some melted bits. I swapped the amp (wireless was discontinued) so I went without it. Works great now going on couple of years. Added Rocketfish wireless.
Sorry to hear about yours, but an amp swap is easy to do!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Hi verb, did you get the same amplifier or replace it with something else? I never used the wireless so it's not required for me. I don't suppose you have the model number of your new amplifier?
I got the replacement directly from Polk! And, with the help and tutelage of one of our most senior members here on CP.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
