Direct Tv Hook up
arni
arni Posts: 4
edited June 2004 in Electronics
I have multiple receivers (3) in different rooms, I would also like to have a tv signal in the garage. So instead of getting an additional one can I split the signal from one of the other rooms and share it to the garage? If so where do i put the spliter, after the receiver before the bedroom tv?
Any help would be great thanks,
Arni.
Post edited by arni on
  • mantis
    mantis Posts: 17,318
    edited June 2004
    NO,
    Dss receivers need a direct feed from the Dish.Depending on what type of dish you have 16,20 or 24 you might need a multiswitch.
    20 and 24 inch dish can support up to 4 runs by itself.No multiswitch is needed.If you have a 18 inch disch,upgrade it to the 20,then you can simply run a line(rg6)to the garage from the dish.
    Sharing dss receivers can be done but you need to have a RF model.This will give you control in the garage.bad part is whatever room you share off of,that room will have to display the same channel.
    To share a room,run a rg6 feedfrom the TV out of the dss receiver to the TV in in the gagare VIA coax input/outputs.You can run line level,but depending on the run,you might need an amp or a powered run.
    Dan
    Dan
  • polkatese
    polkatese Posts: 6,767
    edited June 2004
    Arni,
    I use this Recoton multiswitch such as this:
    http://www.bestbuy.com/site/olspage.jsp?id=1051384450384&skuId=3213597&type=product
    it goes from satellite to the switch to rooms. It works great, and it doesn't need powered. I tried a regular coax splitter and it didn't work. This one is a bit pricy, but it works.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
