What is your noise floor level?
treitz3
I just discovered that I have a "relatively" low noise floor.
Both during the day and during the night....especially at night.
There is about a 10Db drop off at night with the HVAC not running (which is NEVER the case....HVAC not running).
What are your SPL levels?
If it wasn't for them damn crickets farting at 100 yards away it'd be pretty quiet here.Gustard X26 Pro DAC
With the ac off, low 30s- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Fridge running in the kitchen and crickets outside
If you are referring to room noise than mine is very quite at night. During the day you got the typical Lawn mower going, loud cars driving by the house etc.
If you are referring to the electrical Noise floor, I'm not sure I never measured it. But I must have had some noise in my dedicated line to my system as I recently installed a new surge protector and noticed a lower noise level, actually I think I eliminated it as my subs and system plays louder at the same volume level as before.Dan
Damn, Rob. I'm movin' into your place! Wow, that is low! Rock on with yo' bad self.
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
