Brand new MAGNIFI MAX SR SOUNDBAR popping noise out of rear speakers
NolanDick
I purchased a new Magnifi max SR last week and am very frustrated with the popping noise out of the rear speakers. It happens despite the connection type (Optical, HDMI, bluetooth). I've connected it to google home so it could get the updates as that's what everyone else says is supposed to fix it but still nothing. Going to return it in a couple days if I can't get it solved. Any help would be really appreciated.
I'll send your issue to a friend at Polk.
SeleniumFalcon wrote: »I'll send your issue to a friend at Polk.
Thank you, I appreciate any help I can get. -
As a test can you turn off your router to see if it is causing interference?
Yeah, I did that. I even moved the router. It's about 15 ft. away now.
and it's popping out of both rear speakers. The other is even further than the 15 ft. -
Thanks, I'll let them know.
My friend is going to contact you via email.
SeleniumFalcon wrote: »My friend is going to contact you via email.
Great I appreciate it. Any idea when, and do you have my email? -
It should be soon and yes I have your email.
SeleniumFalcon wrote: »It should be soon and yes I have your email.
Great can't wait. Would love to make this work. Still haven't heard anything though.
